Backlit Portable 5126 — Is your backlight this dim?
2,185
Hi, folks.
I know the Portable's backlight is rated at a meager 53 nits, but if any of you own a 5126 Backlit Portable, could you please tell me if your backlight is as dim as mine?
I filmed the short video below under standard room lighting with a rather strong LED room light, and then an LED desk light at right of the Portable. The light isn't so bright to have blown out the light colored plastics or anything. You can see how dim the LCD is normally without backlight, and while the backlight helps, it's not that great at all.
I'm just curious if the backlight strength was this weak originally. Do these CCFL tubes slowly dim over time?
Another thing that has me confused is why all the photos of the 5126 I've seen tend to show a more blue backlight, rather than the slightly yellowish backlight I see (which is what you see below). The video below is perfectly white balanced.
Thanks.
Tagging: @nottomhanks , @Paolo B , @techknight , @Stephen
nottomhanks
102
Hey @JDW , I have been having serious issues with my Portable over the last six months. My Backlight flickers with any disk activity, and I think I may have burned out my MacEffects 8Mb ram card, so I am hurting. I might need to send it to @techknight to get things back to normal, but I'm afraid I'm not really able to do any reliable troubleshooting at this time unfortunately... :-(
  • Sad
2,185
Very sorry to hear that. I do hope your RAM card is OK.
I've heard that CCFL backlight tubes can flicker when dying, so hopefully it's nothing more than that. But as to why your RAM card doesn't work, well, can you run the Portable without the card installed at all, just using the onboard 1MB? If so, can you try only using 4MB on the card rather than the full RAM (no jumper)?
I have the same MacEffects RAM card and I've been using only 4MB on it because of the 25% slowdown associated with using all the RAM on the card.
If you ultimately do get a hold of TechKnight, please tell him that I've been desperately trying to get replies from him for over a month now. He needs to only check his PMs from me.
2,185
I found a YouTube video from a fellow opening his 5126 LCD housing, and took the following still images from it...
As you can see from the above, two wires lead from the INVERTER UNIT to each end of what should be a single CCFL tube inside that metal shield.
The metal shield appears to be mounted in place using a black rivet topped with glue on either side.
I've never tried to break the glue and remove the rivet on mine.
But on this 5126 LCD shown in this video by @techknight , his rivets don't seem to be glued...
When watching one of TechKnights videos, I see that he retrofitted an EL backlight, which leads me to wonder if the CCFL used in the 5126 isn't replaceable. If it is replaceable, why go with an EL?
Paolo B
309
181
Hi, folks.
I don’t have a backlit, but surely it does look quite dim. For example, the Pb100 I have looks much brighter. Replacing the tubes is very easy, but sourcing the exact specs might be tricky.
This company may help, though…
2,185
Problem now is that I cannot for the life of me get the LCD housing open. SOMEHOW I was able to do it in the past because I recapped the INVERTER board. But no matter what I try now, it simply will not come open.
WHAT I'VE TRIED (AFTER REMOVING THE 2 SCREWS):
1. SERVICE SOURCE says to insert tiny screwdriver, push, maybe even rock it left and right, and then you should be able to move half of the housing. Well, NOPE!
2. Apple's Official Disassembly Video basically says the same thing starting at 26:36 here:
NOPE!
3. Then tried this guy's prying technique at the ribbon cable side of the display housing. I can get that part to open a couple millimeters, but it's latched hared on the opposite end of the housing and unlike that guy, I simply CANNOT GET IT OPEN!
4. I then read another guy who basically said the same thing as the guy in #3 above, but this guy suggesting prying out 360° all around, but I simply cannot get a tiny screwdriver on the sides where the handle is, nor can I do so at the top part where the screws were.
The photo below shows as far as I can get it open, and if I try to open it more, I fear something inside gonna break…
2,185
It took two hours, but I was finally able to open the plastic LCD housing, and in this video I show the CFL tube.
EDIT: I later found that the piece of tape does not secure the paper wrapped around the tube. The tape seems to be there to better ensure the paper rolled around the tube won't ever come open. But the paper itself is very securely GLUED. And trying to get that paper off would likely result in damage to the paper. So the only means of removal would be to somehow removed the glued black endcaps so as to slide the tube out, then slide a new tube back in.
Reactions: Kai Robinson
2,185
@Kai Robinson
Thank you so much for your reply!
In answer to your question, I’ve been desperate over the past month to get in touch with @techknight because he has the most experience repairing these machines and he also decided NOT to use a replacement CCFL tube or even LEDs, and he instead opted for an EL backlight, for reasons I don’t fully understand. That’s one of the many reasons I’m trying to get in touch with him.
TechKnight obviously found some issue with using LEDs (and maybe even CCFL), which is why he went with EL. But he was unable to fit the EL’s driver circuitry inside the machine because it’s so big, and that’s a deal breaker for anyone trying to mimic his solution.
So because I am unable to consult with the expert on this topic (TechKnight), my thinking is that if I can buy an exact CCFL tube replacement and also figure out how to get these black end caps off without breaking anything (see my video), then that will at least make the screen more readable for me for now. That will restore my sanity, Kai, and allow me to plan a for a possible LED backlight replacement without a need to rush. In other words, a replacement CCFL tube would be an interim solution for me.
A few minutes ago, I fired off an email to the following CCFL company, asking them their thoughts:
https://www.ccflwarehouse.com/cclawiwi.html
I made a short video specifically for them, showing them some measurements that I made and asking specifically how to get those heat shrink in caps off without harming anything. Because if I remove them and break something and then they tell me they can’t offer me a replacement CCFL tube, then I won’t have any back light at all, and that’s a big problem because I’m making a formal video about my Portable now. I need people to see the LCD screen when they watch my video.
The black end caps on the CCFL tube are really hard when I try to squish them with my fingers. It’s more than just two layers of heat shrink. I think Apple even used glue inside the heat shrink to make sure the heat shrink wouldn’t come off.
techknight
127
129
North Carolina
That backlight level is normal from what I have seen. Mine is like that, all of the ones I have worked on are like that.
Flickering is also normal on some of them I noticed, it depends on the severity. the inverter design is an odd duck but its early for the time period.
2,185
I've seen "photos only" of screens that have very bright backlight. And the color is different too. Mine is dim and rather yellow like you saw earlier in this thread, but the bright ones like the photo below seem bluish...
the inverter design is an odd duck ...
Is that why you've never swapped the stock CCFL tube before?
I fired off an email to the company below last week:
techknight
127
129
North Carolina
Problem with comparing against photos are the 40 years of technology gap in between, including photography and lighting. Apples to oranges, not even worth arguing about. That energy can be spent elsewhere.
As far as swapping CCFL bulbs? Never have. Why? Because I never had to. I only swap those when they die or are near death.
2,185
Understood. Thank you!
Quick unrelated question...
Starting from 34:46 in your video, your battery is removed and your recapped AC Adapter is connected to the Battery Eliminator but your 5126 wouldn't boot. You then disconnected the AC Adapter's plug from the Battery Eliminator and connected it to the Portables AC Power plug. I am very surprised to see it booted!
Did you have the stock wire harness still connected, but the Eliminator's harness disconnected?
If not, how would plugging the AC Adapter into the stock DC input be able to boot your 5126?
Thanks.
techknight
127
129
North Carolina
I don't remember. Been too long ago.
Pretty sure it backfeeds the supercaps. Not really supported, but i suppose it works all the same.
2,185
Folks,
Here are more photos of the CCFL tube, end caps, and texture of the diffuser panel behind the LCD...
Diameter of the CCFL tube, as measured nearest the end caps (I can expose about 1mm or so of the tube from under the paper covering it, at the ends):
Back side of LCD (backlight tube shown at top):
Tiny metal clips that hold the metal CCFL cover in place:
Zoom shot showing the backlight diffuser plate partially pulled out, which is why it's darker at the top:
Metal CCFL cover removed:
Zoom shots showing the texture of the diffuser plate (which is why the LCDs of these M5126 models are so darned hard to see WITHOUT the backlight ON):
Zoom shots showing the 1mm or so of the glass CCFL tube I can see between the black end caps and the reflective paper covering the tube:
Zoom shots of the black goo coming out of the heatshrink on the wire side:
Front photo of LCD with CCFL & diffuser plate locked in place at left:
Front photo of LCD with CCFL & diffuser plate partially pulled out:
2,185
Here are measurements I made today. Just FYI, for those of you who appreciate FYI's, that is. :)
Between Metal Inner Edges (see photo above)
• Diagonal: 26.5 cm (10.43")
• Width: 22.1 cm (8.70")
• Height: 15.5 cm (6.10")
PCB Size (see photo above)
• Width: 26.1 cm (10.28")
• Height: 17.6 cm (6.93")
Pixel Area
• Diagonal: 24.9 cm (9.80")
• Width: 21.0 cm (8.27")
• Height: 13.2 cm (5.20")
Diffuser Panel
• Height: 14.5 cm (5.71")
• Width: 23.4 cm (9.21")
• Thickness: 2 mm (0.079") (approximate because I didn't use my calipers)
CCFL Tube Size
• Visible Length (excluding both black heat-shrinked end caps): 14.4cm
• End of Tube covered by heatshrink): 4mm on each side (approximate)
• Diameter: 5mm
