4,1 MacPro upgrade
Markintosh
60
USA
Hi Gang!
I'm interested in bringing my '09 Pro past OS 10.11
I understand flashing the firmware can make the Pro "think" it's a 5,1 - therefore getting past the 10.11 install limit.
I have an old i7 iMac that died due to the graphics card failure we're all familiar with.
I installed the iMac HDD into my 4,1 to retain the data on the iMac.
One day I booted from the iMac HDD and, to my surprise, my unmodified 4,1 was running 10.13!!
My question is: Have I bypassed the NEED of upgrading my firmware if 10.13 can boot? I did not run exhaustive tests-can I run with this HDD without any issues?
Does anyone have experience with this?
Thanks in advance!
--Mark
Nixontheknight
206
38
Hi Gang!
Thanks in advance!
--Mark
you can push it even further with OpenCore Legacy Patcher
607
Thanks in advance!
--Mark
Upgrading to 5,1 increases the CPU and RAM capacities (or speed). Check out House of Moth.
Your iMac can be restored to working order with a graphics card replacement, not a simple task, but doable. Or you can turn the iMac into an external display.
Markintosh
60
USA
That’s good to know!
10.13 & my current hardware is actually fine for my use.
i just wanted to know if proceeding with my 10.13 HDD would work correctly, or will I experience erratic behavior and possible corruptions?
