I Got a New Kaypro PC-30: How Does It Work?
_nec6678
53
15
Hey! Today I just got a Kaypro PC-30 for $25 dollars, and it appears to be in good condition. Where I got it, there was another Kaypro, a Kaypro 4, but it wasn't for sale yet. I know practically nothing about Kaypro PCs, but it looked cool and was a good price, so I bought it. Once I got it home, I tried plugging in a DB9 to DE-15 cable into the Kaypro and a monitor, but got no display. It also had some coaxial ports on the same card, so I tried plugging those in to and connecting them to a monitor. Either something doesn't work, or I'm just being silly (probably the latter). However, I do hear three beeps a little bit after I turn it on. Also, there is no hard drive so I don't have an operating system. When I insert a floppy, it spins for a couple seconds before stopping, but the head does not move.
_nec6678
53
15
Exciting update! After playing around with it for a bit more, I realized it would be a good idea to look up the manual for the graphics card! it is an ATI EGA Wonder. I found the microswitch configuration I needed for the composite output, and set the switches to that, and it works! I get a display out! Unfortunately, I don't have a keyboard or mouse so my use will be quite limited until then.
chuma
26
16
Canada
www.chuma.org
You probably already found https://kayprojournal.com/index.php/Kaypro_PC which has lots of info about this machine. It's essentially a PC/XT clone with a passive backplane instead of a motherboard.
With a Raspberry Pi Pico, a level shifter (or circuitry), and a USB OTG cable, you can build an XT keyboard adapter. I did this recently for a project I'm working where I also needed an XT compatible keyboard, but don't have one, and works like a charm:
I didn't build the level shifter out of components, I just used one of these and flashed the ps2pico-XT-alt.uf2 firmware. Works like a charm even as an insane looking bundle of hookup wires and boards all over the place :cool:
