277
339
The Macintosh Portable has a certain cachet. It possesses an exquisite keyboard, a crisp screen, and a complete set of ports and slots. Unfortunately, the size, weight, and price were derided at the time of launch.
Presently, the challenges of a Portable are:
1. Most cases are cracked due to transportation and use. The plastic is repairable, is not brittle like the Quadra 800/840AV series, and so this should be overlooked as a reason to avoid owning a Portable. Unless you run a museum, don't sweat a few repaired cracks and missing tabs. Happy little accidents.
2. The batteries are dead. These can be replaced by modern 3D printed cases and gel cells.
3. Capacitors have leaked. The capacitors are no worse than other Macs from the era and most can be recapped easily.
4. The memory cards are unavailable. Occasionally, modern reproductions are produced depending on NOS chip supply. Surprisingly, this is a significant limitation. Most vintage machines (except the IIfx and 4400) can easily have their memories maxed out. If you buy a Portable that turns out to be unrepairable, don't discard the memory card! On eBay, make sure there is a picture of the slots to ensure there is a memory card installed, otherwise you're stuck with only 1 MB, which isn't enough for System 7.
5. The power circuitry is seriously flawed. In hindsight, this is the biggest problem with the Portable. It doesn't work (and can be damaged) without a healthy battery installed, a higher-current AC adapter from a PowerBook fits perfectly and can kill the Portable, the 5120 has a hybrid module that decays and can die from capacitor juice (replacements readily available), and if you hook up your bench supply to only one of the two +V inputs you can kill a whole line of chips.
Based on the last reason, I recommend getting experience with repairing other Macs before you tackle a Portable.
MY ATTEMPTS
I purchased three 5120 and two 5126 portables over the years. They all needed plastic repairs (done), new batteries (done), recaps (done), 4 new hard drives (SD card emulators done), and the 5120s needed hybrid modules (done). The 5126s came with decent memory cards (done). One of the 5120s came with a 5 MB memory card that just needed Deoxit and reseating the chips/SIMMs (done).
The 5126 backlit Portables are working perfectly now, except one has a screen with a dead (always on) pixel. No worries.
All three 5120 boards were dead even after the recap and hybrid replacement. I suspect I am at fault for at least one of the failures. The biggest mistake when repairing these machines is providing power during testing to only one of the +V inputs. I assumed they were tied together on the PCB. I have since created an adapter cut from an old hard drive cable and the top and bottom pair crimped. I use 6.3V with a 1 amp limit on my bench supply (I don't repair with the hard drive installed).
SCREEN
For bench testing, I used a proprietary VGA adapter created by @Androda and sold by Joe's computer museum:
Read the warnings on that page. ABSOLUTELY DO NOT CONNECT A VGA CABLE DIRECTLY TO THE BACK OF THE PORTABLE ITSELF. Also, while you're at Joe's computer museum, buy the BlueSCSI Portable Adapter and (if you own a 5120) a Hybrid module.
The adapter rules out issues with the Portable LCD screen and it is easier to work with a freestanding modern display, rather than propping up the panel. If you see nothing coming out of the VGA adapter, it is possible that this portion of the Portable is damaged. In that case, try the Portable's LCD screen to be sure.
KEYBOARD
I plugged in the Portable's keyboard and mouse for my tests. Pressing a key on the keyboard powers up the Portable.
DRIVES
I used both a FloppyEMU and ZuluSCSI during bench testing. It's nice to have both in case either the SCSI or SWIM chip is blown. I first power up without either drive attached. There is no reason to risk damage to them until you validate that the motherboard can reach the flashing question mark.
SPEAKER
I like to have a speaker plugged in, just in case it gives me a sign of life.
FIRST BOARD (Impossible)
My first 5120 board has a dead power manager chip. The current draw is 33 mA. Pressing the keyboard shows no sign of life and the current draw doesn't change. In a healthy computer, the current draw is 10 mA, going to 300 mA and up when the space bar is pressed.
Without power, I checked the resistance of both the reset and interrupt buttons when pressed (<5 ohm)/released (> 10 kilohm) to make sure they weren't stuck. With power, I tried pressing and holding the pair of buttons to 'reboot' the power manager. Nothing.
I checked for broken traces and created a pinout diagram.
Ultimately, I have thrown in the towel on this Portable. I swapped its best parts (a nice screen and some plastic elements) with one of the other Portables. I will keep the board for parts or in case someone comes up with the replacement power manager.
SECOND BOARD (Easy Peasy)
The second portable had two obvious issues that were easily fixed. The trace (right side of the image below) and the corroded leg on the 244 (left side of image). If you find any issues like this, look around to be sure you found them all. Also, resolder all the legs of nearby chips if any leg shows dullness or corrosion.
THIRD BOARD (Complicated Success)
This last Portable motherboard did not make a startup sound and shows vertical pinstripes. However, it begins with a low current draw (10 mA) and wakes (~300 mA) when the keyboard is pressed. So, the power manager is working.
The slots on the Portable have lots of valuable pins for testing. (Please note that the ROM and RAM slots are numbered from bottom to top on the motherboard but top to bottom on the schematic, whereas the PDS slot numbering matches the motherboard and schematic.)
Any pin with an asterisk '*' at the end of the name means it is activated when the signal goes low. For example, SYS_PWR* is 5V when the Portable is sleeping and 0V when the Portable is awake. Got it? Opposite day. SYS_PWR* = 0 = GOOD.
ROM_CS* 0V indicates the ROM is being accessed. ROM_CS*=0=GOOD.
BERR* 0V says a bad address was accessed. BERR*=0=BAD.
SYS_RST* 0V means the computer is halted waiting for power to stabilize or the computer will now restart. SYS_RST*=0 steady=BAD.
Get yourself some male-to-male jumper test leads and male-to-female jumper test leads for connecting an oscilloscope to the ports. I really like these:
In the image below, I am watching BERR* (bus error) and SYS_RST* (system reset).
On this board, I noticed that after power up, this computer would show bus error, then system reset (correct: it should reset after a bad address), followed by four ROM accesses, followed by quiet, and then repeat.
What's going on? Well, when the power manager tells the 68000 to proceed (SYS_RESET* 5V = GOOD, SYS_PWR* 0V = GOOD), the following happens:
1. The CPU sets the address lines to $00000000 to read the ROM.
2. The CPU GLU sees this and sets ROM_CS* (ROM chip select) to 0V. Remember, low signal is active on pins with an asterisk. ROM_CS*=0=GOOD
3. The ROM chips see the ROM_CS* signal on their pin 22. The LO ROM chip outputs 8 bits (D0-D7). The HI ROM chip outputs 8 bits (D8-D15). Why? This is 16-bits. Ever heard of a 16-bit data bus? That's what this is.
4. The CPU reads all 16 bits of data and sets the address to $00000002.
5. The CPU GLU disabled ROM_CS* (5V) when the CPU completed the read. But, it now sees the request for $00000002 and sets ROM_CS* to 0V again. ROM outputs.
6. The CPU reads those next 16 bits (32 so far) and stores that as the stack pointer. It then sets the address to $00000004.
7. CPU GLU, ROM supply the next 16 bits. CPU sets to address $00000006. CPU GLU etc ROM supply the next 16 bits.
8. The CPU jumps to the address specified in those most recent 32 bits.
To summarize, read the first 4 bytes of ROM (2 bytes at a time) for the stack pointer. Read the next 4 bytes of ROM (2 bytes at a time) for the address pointer.
The next step in a healthy Portable should be:
9. CPU sets the address to $0090002A because this was the most recent 32-bits sent from the ROM. If you disassemble the ROM (or a ROM file), you'll find these are the fourth through eighth bytes in the ROM.
10. A magical moment for the CPU GLU. It says "Wow! You found the final home for the ROM. I am remapping it to $009XXXXX from now on." Cool huh? ROM started at $000XXXXX at power up, but from now on will be $009XXXXX. The CPU GLU will also set the ROM_CS* active (0V) because it knows the CPU wants to read the next instruction from ROM at this new address.
On my Portable, however, ROM_CS* was not going low at this point. I got four good pulses (reads the first 8 bytes, 16 bits at a time) followed by this moment when ROM_CS* was not being activated by the CPU GLU. Why not?
Since the circuit was auto restarting over and over, I connected my oscilloscope to each data pin on the CPU and recorded the low/high pattern. In a spreadsheet, it looked like this:
The third+fourth row should be $0090002A, but instead the data from the ROM reads $00800022. D4 is always low.
What is address $00800022 on the Portable? Nothing. Bus error! Reset! The CPU is doing its job -- it is just being told the wrong information.
SWIM DROWNING D4
I checked the traces with a multimeter. They're good. Is the ROM faulty? Possible but unlikely.
@techknight advises people to replace the SWIM on their Portable. Why? On a hunch, I snipped D4 on the SWIM.
Chime! Good ROM data.
The SWIM can fail passively (no response) or actively (interfering with other signals). My SWIM failed actively on pin D4. Yours may differ.
The Portable now got to here (see image below). We see a valid pattern on the screen. This is really good news. It means video works, the CPU works, the ROM works (this pattern was read from ROM), etc, etc etc. But, look closely and you'll notice this isn't the normal every-other-pixel pattern. This is the 'I'm testing memory or other stuff' diagonal pattern. No cursor and no disk icon.
I removed the SWIM with hot air. Same diagonal patten. Some people think the Portable can boot with the SWIM removed. It cannot.
I substituted the SWIM from a dead PowerBook 170 and was greeted with:
Success.
This particular board also needed a sound crash fix which I will describe some other time. But, hopefully this demonstrates the start up sequence and a technique that you can use to hunt down problems in your Portable.
- David
techknight
131
132
North Carolina
MY ATTEMPTS
SCREEN
KEYBOARD
DRIVES
SPEAKER
SWIM DROWNING D4
Success.
- David
I have occasionally had to bypass the high-side load switch MOSFET for the sound circuitry because it gets noisy if not, 12V hovers around 4V and causes a lot of noise. They did away with this circuit in the backlit portable, so it is safe to do.
Reactions: JDW and David Cook
277
339
I am so glad you said that, because that's what I had to do to get the Portable to not crash when playing sounds. I was embarrassed to post my 'hack' because I felt it wasn't a solution. But, given how many Portables you've worked on, and given that Apple disabled this in the backlit model, it appears to be a flaw in the design.
- David
techknight
131
132
North Carolina
It absolutely was a flaw, and what I find even more interesting is some portables do this, while others do not. I think its crap getting in the middle layers or whatnot. But thats just a wild hairbrained guess.
Reactions: David Cook and JDW
2,224
Fantastically detailed repair thread, @David Cook — thank you!
You said: "The biggest mistake when repairing these machines is providing power during testing to only one of the +V inputs."
QUESTION: Is your photo below showing us what we SHOULD do or should NOT do? (What my eyes see in that photo: (1) the same Ground entering the bottom two connector slots via the BLK & ORG wires, and (2) the same +6.3Vdc@1A (via benchtop PSU) entering the top two connector slots via the RED & BLK wires. Correct or Incorrect?)
277
339
I regret reusing an old hard drive cable for this photo -- as the color of the wires is confusing when used on a Portable. Give me a minute and I'll upload a better diagram.
571
www.floodgap.com
Specifically, what does this look like? I have a working prototype Portable with bad sound (caps were done), so I'm interested to hear if this might fix it.
I also have a dead Portable that didn't come back to life after a recap. I'm suspecting the hybrid but I could be wrong. It was probably used with a PowerBook adapter - has anyone tried repairing a Portable broken in that fashion?
2,224
I have a working prototype Portable with bad sound (caps were done)...
Bad sound like @David Cook and myself, actually. We both have 5126 machines which produce a "tick" sound every 10 seconds. I call that "bad sound." David explains the reason for the tick anomaly here:
Apple patched the sound watch code to keep sound power enabled with a check every 10 seconds. Unfortunately, even when sound power is already enabled, the code writes to the Power Manager, causing a pop. Quiet Portable replaces this code with an algorithm that turns power on only if it is off on a backlit Portable.​
If you also have a pop/tick sound like that, the good news is that David programmed the cure here:
That Extension doesn't do anything to address my "noisy audio," but it does restore my sanity. That tick every 10 seconds was horrible. But the audio in general on my fully recapped and trace-repaired Portable 5126 is noisy from the speaker and from the headphone jack (I can endure it at volume level 3, but not level 7), so I too am interesting in hearing more details about the @techknight fix which involves bypassing "the high-side load switch MOSFET for the sound circuitry."
2,224
Details of "bad audio" are important, so thank you for clarifying. But in my mind, bad audio is bad audio, and all bad audio needs to be addressed.
My Portable has no volume level issues. The loudness is about what I would expect, both from the speaker and headphone jack. It's never too soft to hear, for example. But the noise is loud enough to be noticeable even at Control Panel Sound Volume level 3.
Sadly, I didn't own a Portable in the late 80's or early 90's, so I have no idea how clean the audio was when the machines were new, either from the speaker or headphone jack. All I've done over the past couple years is question other Portable owners, but their replies vary. Some people don't notice any noise, so I suspect those people have good audio. And not every 5126 Portable owner reports the tick sound every 10 seconds either.
277
339
Here is a better look at the Portable battery input connector (J17) on the motherboard. Like other power connectors (such as on the Macintosh II, IIcx, or LC series), the ground inputs are actually connected together on the PCB itself. However, unlike other power connectors, the +V inputs are actually split up and go to different parts of the board.
BATTERY_TEST (poorly named) pin 3 of J17 is the main power source. It goes through fuse F1, meets up with the AC power adapter input, and supplies power to everything in the Portable.
BATTERY_SENSE pin 1 of J17 only goes to pin 25 of the hybrid module pin. (This information is for the 5120. I don't have a schematic for the 5126 and don't have mine disassembled to check.)
Because the battery connections are not tied together on the PCB, there is a danger when only one portion of the circuit receives power. Apparently, the hybrid module is unable to regulate power input when only the BATTERY_TEST terminal is connected, as the hybrid module sees 0V (or float really) on the BATTERY_SENSE pin.
So, you should always hard-wire your +V side of your harness together when using a bench power supply. Might as well do the same for GND. See below.
Isn't there a problem if Apple intended for the input to be split? Nope. On my Portables, Apple also wired the +V together before reaching the connector. See the purple circle on the bottom left of the image below. Apple has a switch that connects the output (to the PCB) to the big lead-acid battery when the plastic battery cover is in place, or the little 9V battery when the battery cover is removed. But, in either case, both wires leading to the PCB input J17 are crimped together.
My harness is marked revision 9. Perhaps Apple originally had a different plan for the +V inputs?
I do have a slightly radical suggestion. Perhaps we all should solder a jumper wire between J17 pins 1 and 3 when recapping our boards, just to avoid future problems where one connection becomes oxidized or loose.
Aside: @JDW would not be happy with the narrow gauge of the wire that provides power to the screen, hard drive, motherboard, memory, modem, etc. Yes, the little wire helps too, since it has been crimped together. But, this doesn't compare to the upgraded wiring harnesses JDW prefers for the SE/30. No accelerators for the Portable, I guess.
277
339
I just repaired another Portable that was crashing when sound played. I decided to put this board in my ultrasonic cleaner. Afterwards, the hybrid module was dead. That's okay -- as I was just experimenting to see if I could get it to last. I replaced the module with a modern part, per usual. I noticed a lot of crud in the pin holes after desoldering the old module. So, I cleaned each hole carefully and then soldered in the new module.
Well, I was pleasantly surprised to find the cleaned Portable no longer crashed when playing sounds. It could be that indeed some crud on the board (or in the hybrid module pin holes) is the source of trouble.
Had the Portable continued to crash after cleaning, my plan was to replace Q3. It is located near a lot of capacitors and I can see how a faulty transistor there could result in voltage issues on the 12V rail.
277
339
I have reached the end of my Macintosh Portable pile. The final Portable did not power on and did not change current usage (as displayed on the bench power supply) when a key was pressed on the keyboard. That suggested a bad Power Manager chip. I originally believed that was a death sentence, so this Portable became my "parts" machine. That is, if another Portable had a broken plastic part, screen, whatever, I would swap it with the "parts" Portable.
This week, I decided to tackle this "parts" machine and see if I could get it working.
1. Using a hot air station, I removed the power manager chip from a PowerBook 100 with a dead screen. I transplanted that chip to the Portable. Both models use the same part. Here's what the PCB looks like underneath the Portable Power Manager chip.
2. I replaced the hybrid module, this time I purchased one from @SuperSVGA. It has a lower profile than the other hybrid modules that I've purchased in the past. So, it can be socketed and still fit in the Portable's case without needed to cut away any plastic. [Note: I actually replaced the module earlier -- so I knew the Power Manager chip was bad and not a consequence of a bad hybrid.]
Between steps 1 and 2, the "parts" Portable booted!
3. The speaker did not make any sounds, but the speaker itself was known to be working. I plugged in headphones and heard sound out the right channel. In Apple's design, only the left channel goes to the speaker. By toning out traces, I discovered the tiny via above the positive pad of C9 was corroded and not making a connection to pin 11 of the SND LEFT chip. I drilled out the via with a tiny drill bit by hand with gentle finger movements. I then ran a 32 AWG bare wire through the via and soldered it to the C9 pad and trace underneath. This restored speaker sound.
4. The Portable crashes when playing a sound. This is now the third time I've run into this. One time was fixed by an ultrasonic cleaning. One time I "fixed" this with a bodge wire to keep sound power enabled. Ala @techknight
I have tried cleaning and resoldering Q6/Q7 without luck. This time, I tried replacing Q3 and verifying the connections and values of C2, C3, C4, C5, C6 and associated resistors. My theory is that inductor L7 kicks in to fill C8 but due to some problem in that portion of the circuit it creates a lot of electrical noise in the 5V line or nearby chips. Despite all of this work, it did not fix the sound crash. So, I once again resorted to a bodge wire to keep sound enabled. This prevents the crash and behaves just like the 5126 (that lacks the ability to turn off the sound).
If I had the energy, I would experiment with replacing VR1, increasing the capacitance of C3, increasing the inductance of L6, or decreasing the capacitance of C8. The theory being that if the step up regulator didn't have to work so hard it wouldn't be so noisy.
5. The trackball was horrible and the cursor kept getting stuck in the vertical axis. I followed @JDW's instructions to clean the bearings, recap the PCB, and replace the old yellow rollers. Now, the trackball is smooth and a delight to use. I did lose an original spring in the process (and replaced it from a random spring collection). Be careful.
6. I used Gorilla clear 5 minute epoxy to repair all of the broken plastic bits on the Frankenstein parts traded with the other Portables. The end result is a bit Kintsugi, without the gold dust. But, it is stable and fits together nicely.
With these repairs, my "parts" machine Portable is now fully functional!
jdoctinker
I’m glad I found this thread! I recently acquired 3 Mac Portables, all non-backlit screen versions. Two were in excellent condition (one was given to me by a friend, and had only been used for about 3 months, then stored- it‘s in excellent shape!). I recapped all 3 boards with cap kits from Console5. Two of them boot/work, including the original hard drive on one. The third suffers from the vertical line issue described in this post (I’ll work on that). However, I have 2 lingering issues- one with each of the functioning Portables: 1. I cannot connect to an AppleTalk network on one, and I don’t think it’s a software issue; 2. The other Portable restarts automatically each time I Shut Down, and I have to remove all power (both batteries and powersupply) to keep it from doing so. Details: 1. I have a few other Macs connected via AppleTalk, but each time I go to ‘Chooser’, and click to activate AppleTalk, it just hangs, requiring a hard reset. The computer is running System 6.0.8. The second Portable connects to AppleTalk no problem, but that computer lacks a hard drive (running off of a BlueSCSI attached via external SCSI with System 6.0.8). When I attach that external drive to Portable #1 and boot from the BlueSCSI, activating AppleTalk via Chooser results in the same hang. So I’m thinking there’s a hardware issue somewhere (but could be wrong). 2. Auto-restarts: i don’t know where to start looking for solutions, but before I start tearing everything apart again, perhaps someone here can provide some focused guidance. All 3 computers have new batteries (sealed acid replacements that I’ve obtained based on feedback on this forum), and I have 3 power supply units: one original that still outputs 7.5V (although may be variable- understood!); one unit I put together using a buck converter and original power supply cord (set to 7.5V and 1.5A max); and a third party supply which has adjustable voltage output and connectors. I’ve tried all 3 power supplies on each computer and they seem to work. As you can probably tell, I’m relatively new to all of this, but very eager/willing to learn. Thank you for considering my issue, and any feedback/guidance is much appreciated!
jdoctinker
Just a quick follow-up: the auto-restart issue turned out to be an easier fix than anticipated- there were a couple of ‘dirty’ areas on the board. Some gentle scrubbing with a toothbrush and 99% isopropyl alcohol cured the ghost restarts!
