XLR8 - Jumper Settings for a Power Computing 180C
RetroTechy
Hi all
I have a power computing 180c which has a XLR8 Mach Speed card in it with a 266mhz ZIF installed in it. For the life of me I can’t get it to boot and think it’s the jumpers which the previous owner may have changed. Can anyone lead me to a solution?
Aah! I have the pdf of this somewhere, I have all the pdfs for the xlr8 gear on my desktop.
Lemme dig it out for you.
RetroTechy
Thanks @Kai Robinson and @alxlab I tried the MACH carrier zip instructions at 266 but it stays frozen at the macintosh logo. This mind you is on the original scsi hdd which occasionally doesn't spin up...
Drake
Emeritus Board Member
794
Completely off topic but I have a brand new XLR8 mouse that would have been packaged with their usb board.
It even looks fast
mg.man
137
71
Ardley, UK
A bit late seeing this... but here are the 'base' settings...
I've also attached the full manual.
If you're trying those settings, it may be a problem with the cache. You might try disabling it in the MAChSpeed control panel - but then you need to fully boot to do so. I "think" the cache is only enabled when the XLR8 Extension is loaded, so booting with Extensions Off may make it possible to open the Control Panel and disable the cache.
  • interex-mach-speed-g3-user-manual.pdf
