Identifying mystery macintosh SE Accelerator/upgrade card
lsi-aigisx86
10
Hey ya'll
For context: About a day ago I had picked up a macintosh SE off of marketplace for about ~100$ with a keyboard and a few ADB mice, the computer was sold as for parts but was in otherwise in good condition, I got home and plugged it in on my bench and it didn't boot properly, showing the dreaded jail bars with no chime, I decided to take a crack at repairing it and took it apart. After sliding the logic board out, I noticed that the PDS slot contained a rather large card that has a 68030 CPU on it along with some ram and an FPGA, just for testing, I removed the card and plugged the board back in, and it seemed to boot fine with out the upgrade card, so that's mystery solved, the analog board, power supply, and motherboard's caps and battery all looked fine (although I will keep an eye on those).
After playing around with the SE, I turned my attention to the upgrade card and I couldn't find any markings on who made it or what it's specifications are, it also seemed to have a header for a vga output port, which was mounted to the back of the SE30, so I'm assuming that this might be able to do video out or something.
Either way, I've attached photos of the card and the failure it produces on startup.
Does anybody know what the card is or what's wrong with it, and how I might be able to go about repairing it? Thanks.
Reactions: JeffC
GreenBar0n
119
76
East Bay Area, CA
Looks like the Mobius 030 without the FPU - found halfway down this page:
From the above link:
MU 1993.06 (photo) Pinouts
Mobius 030: SE, Classic (25, 33MHz, opt FPU, 16MB)​
by Mobius Technologies Inc., Emeryville CA (TIL04628)
Clip on, Extended Video
Reactions: JDW and JeffC
GreenBar0n
119
76
East Bay Area, CA
Regarding the Mobius not working: looks like you have the 25MHz version and according to Page 7 of the manual listed above, I'd guess you're having a memory issue. The manual says you need to have all the same size and type SIMM modules, it looks like you have two different types in there. Maybe try a matching quad set.
Garrett
159
South Carolina
That's the first time I've ever seen a 68EC030 in use on a Mac. Was the lack of MMU acceptable on a machine that shipped with a 68000 CPU? Unsure if that's the cause of any issues but interesting to see nonetheless.
phipli
264
Yeah, as others have said that looks like a Mobius.
You can either use their drivers, or the GemStart driver works just fine with it too.
Yeah, my Mobius came with a 68EC030 too. They don't need the MMU unless you're doing something that needs Virtual. I swapped a proper 030 into mine. I believe you can actually boot a later Mac with a 68EC040 in some PDS upgrades in a IIci or whatever, it just limits you to 8MB of RAM if I remember.
phipli
264
I'd be suprised if it was VGA - are you sure it doesn't have 9 pins?
It does do video out - depending on the option yours came with... pause... yours is a Full Page Display (portrait) version I think, with the 57MHz clock. Some did Two Page Display, but they have something around a 100MHz clock in the same location.
I've not bothered getting mine to do video - mine is also Full Page, it is a bit of a funny resolution and doesn't work very well on any of the monitors I own because it is taller than it is wide.
phipli
264
I would assume the card has memory that worked at some point and is set up right. My assumptions would be that the contacts on the connector need cleaning, or that the PSU is a little bit weak and the voltage drops just too low with the card installed.
Install the card, power on and then use a multimeter to measure the voltage between one of the lugs and the 5th hole in from the top left on the foppy drive port on the back of the SE. Let us know what it is. You might need to... cough... stick a large paperclip in the hole on the floppy port. Take super care not to short it to anything, including any of the metal housing of the port, or things go bang.
lsi-aigisx86
10
Wow, good stuff everyone, I'll probably take phipli's suggestion and clean/reseat the accelerator card, or maybe swap the memory from my SE's motherboard onto it to see if it works, I don't know if the SE itself needs memory when it has an accelerator installed, the documentation suggests it doesn't, But I don't have any spare 30 pin memory, the guy I bought it from did mention that it used to work and just sat for a long time, so bad contacts/sagging voltage/failed memory is the likely culprit, As for the video out, I don't really care for it, I prefer this to just stay an all in one machine.
I won't have much time to tinker with this until tomorrow night, but in the near future I do plan to max this thing out, ideally I'd want to swap in 4 4mb SIMMs so I can have 16mb of ram, along with swapping in a 68882 FPU for moar floating point performance. But I'll update when I get off work and get time.
In the mean time, any suggestions for pimpin' out my SE? :)
lsi-aigisx86
10
So updates, I have been able to confirm that the power supply is good, both with and without the accelerator that 5 volt and 12 volt rail stay mostly the same, I'd like the swap/reseat the memory but I can't seem to figure out for the life of me how to remove the simms on the accelerator, the macintosh board itself is straight foward but I can't seem to do it on the accelerator itself
lsi-aigisx86
10
The voltage with the card installed reads at 4.90v, without the card installed, the voltage reads at 5.00V
Some more updates, I decided to reseat the ram on the card, I finally figured out how to remove it, it didn't seem to make a difference, the card behaved the same with the ram installed and without the ram installed, I then decided to swap the ram from the mobius into my SE's board and it does boot with the ram (though I didn't remove the little 256k jumper).
phipli
264
4.90v is a fair drop on one of these machines. I wouldn't assume that that wasn't the issue. It should work, but I wouldn't assume that is good.
A lot of us with accelerator cards set the voltage so that it is 5.1v without an accelerator.
An SE/30 (yes, different machine) wont initialise the video properly at voltages much below 4.9v.
lsi-aigisx86
10
Update, so I did get it working and installed system 7.1, I solution was to reseat the 68EC030 CPU, and that fixed it. mystery solved I guess.
It came with a good 4mb of ram but now I'm interested in pushing this thing my questions are:
1. Would I see an improvement from dropping in a full 68030 (instead of a 68EC030)
2. Could I swap in a 33mhz 68030 and swap in a faster crystal to match?
3. Would 16mb of ram be worth the upgrade
4. Can I swap in a 68882 FPU and would it be worth it?
phipli
264
Good news :) I've seen that before with DOS cards, just re-seating the CPU got them running.
Not an improvement, but it would open up the possibility of installing 16MB of RAM.
The specific version of the card you have wont overclock sadly, in my personal experience. There are two variants - one with an exactly 25.0MHz CPU, which overclocks, and one with a 25.175MHz clock, which seems to use the clock to derive some other clocks that it needs to be right. I could be wrong, I didn't spend long investigating.
That... is up to you? It depends what software you want to run on it. I do personally have 16MB of RAM in my upgraded SE.
Yes, this would be worth it. Note that you can independently clock the FPU, so if you fit a, hypothetically, 50MHz grade 68882, you could clock it at 50MHz and get very fast maths performance, even if your CPU was only 25MHz. Alternatively, if you can only find a 16MHz part and don't want to overclock it, you could fit a 16MHz clock and select the secondary clock source with the jumpers the same way.
