Mechanical issue with Miniscribe
VicNor
Sweden
I kept a Miniscribe from a SE that I restored and sold off a couple of years ago. I've only got it to spin up twice - both involved that I "applied" oil (synthetic sewing machine oil and Singer super oil respecitively) to the stem of the centre spindle. Then I work it out like crazy. At first it's stiff but it improves a lot after workout. I'm don't feel that not much of the oil get's where it needs to go because of the little disk (that keeps the Pabst motor and platter package/assembly in place) is in the way.
My question: Is there a way to remove the little disk to properly lubricate the drive so it can easily spin up again? I don't wish to open up the drive and expose the platters. Or should I just go yolo and squirt some WD-40 in there to loosen up/dislodge any grime?
PS There's nothing of importance to me on this drive and I have already imaged it and copied the content - twice.
VicNor
Sweden
This bugger. How do I remove it? Is it possible? Do I need a special tool or is it bulted on so it's impossible? I've tried to lift it with a flat screw driver but that doesn't help.
Or is the Papst motor on the Miniscribe constructed so you can only relubricate it if you open up on the platter side the harddrive?
PS I've googled this problem and it doesn't seem like there's a known solution. If YOU think that you can help, this is your time to shine.
614
That looks to me like a threaded on nut, that probably requires a special spanner tool. You can use a needle nose pliers opened up to fit the notches, or maybe a lock ring type pliers. Or use a single flathead and a tool to tap/strike the flat-head to unscrew it. But since its a hard drive, I would not suggest the latter (impact maintenance) with the flat-head.
VicNor
Sweden
Thanks! I'll try to goto the hardware store next week to find a spanner tool that'll work.
phipli
261
Unless you're very lucky with an angle grinder or bicycle tool, you might do best to ask for "circlip pliers". Get straight ones rather than 90 degree ones because it will be easier to push down.
If they're not good enough, spanners for this kind of thing, you usually end up having to make your own. Broken drill bits can make good pins and mount them in a piece of flat steel at the right distance... but like I said, you might manage with a pair of circlip pliers.
MacOfAllTrades
257
261
best of lluck! I have one from my SE and I couldn’t make it happy. I ended up jiggering up a raspberry pi with a motor controller and GPIO’ing to my BlueSCSI’s activity LED pin and wrote a little program that would just drive the miniscribe motor to spin some whenever the LED activity light comes on on the BlueSCSI — it’s fun and makes the noises I want so bad :D
Edit: link to git repo with movie to hear the sounds
