281
350
I just bought a Dynamic Engineering Macintosh Portable RAM card with 2 MB of RAM installed.
I also purchased new old-stock Toshiba TC 518512FL-80 PSRAM chips to bring the card up to 8 megabytes. My plan is to use this on a 5120 (non-backlight) Portable.
The jumpers on the 2MB card are all installed except E1. I've seen a picture of this model of card with all the memory populated, where only jumper E3 is removed. So, that's what I intend to do.
Can anyone tell me (@techknight?) the jumper configurations? Is there anything I need to do with them to switch between a 5120 and a 5126? Is there a jumper to reduce memory to 7 MB on the card so that this can max out a 5126 but then be switched back to 8 MB to max out a 5120?
Thank you in advance,
David
281
350
I have soldered on all the RAM. It works great in System 7.1 on a 5120 Portable. It shows 9MB total and passes all the memory test applications.
However, in System 6.0.8, it crashes when doing something as simple as displaying the About box in the Finder. I recall reading about a solution for this, but I can't seem to locate it on the forums. Does anyone remember?
281
350
As a workaround, adding a >=1MB RAM disk in the Portable control panel seems to prevent crashing.
The error is a memory manager error. That's suggests a bug or limit in System 6 beyond 8 MB. I tried using System 6.0.8L without success. I wonder whether a Macintosh LC with > 8MB will crash. I'm going to try it.
Garrett
159
South Carolina
Great work! I saw this card on eBay as well - glad someone here snatched it up. Looks like the same RAM ICs that the PowerBook 1xx series uses. Did you have to tinker with the jumpers to get it working? I wonder why Dynamic Engineering didn't use the dedicated RAM expansion connector, but rather the PDS interface... access to more signals not present on the RAM slot?
281
350
Yes. For 8 MB, I moved E3 to E1. So, all jumpers populated except E3. I will play with it further to figure out how to make it 7 MB for use in the 5126.
I believe the RAM slot is limited to 4 MB (recent recreations use an extra wire to provide more). Additionally, the system provides the refresh and data ready signals for the RAM slot. On the PDS slot, the card has complete control.
I tested this. It does not crash. But, it does bump up the amount of memory consumed by the system to keep application memory <= 8MB in System 6. That is, even though the LC memory map places ROM such that 10 MB of contiguous memory is available in 24-bit mode, it still limits it to 8MB in System 6.
281
350
It looks like the jumpers follow a predictable binary pattern
EO=+1MB
E1=+2MB
E2=+4MB
E3=+8MB
E4=unknown
So, to get +8MB (9 in total with motherboard 1MB), pull jumper E3. To get +7MB (8 in total), keep E3 but pull E2+E1+E0. This explains why the board with 2 megabytes already soldered to it had E1 pulled.
Reactions: bakkus
techknight
140
138
North Carolina
Pretty sure I have the schematics and PAL code (on hardcopy) for this card. I cannot recall if i ever made that public or not. I think i may have on the Discord.
Reactions: David Cook
Garrett
159
South Carolina
Wow, this is so cool! Thanks for posting. I suppose a card like this could be recreated, if it weren't for the missing PLD code.
campbellashe
62
40
Asheville, NC
Hi all,
Following up on the files techknight posted earlier in this thread-- yes I've been using Claude to help analyze — I've been working through the Dynamic Engineering Portable RAM PAL sources and schematics, trying to get far enough to actually recreate this board. As far as I can tell there are none available to buy, so building from scratch seems like the only path.
I've gone through all three PAL source files from techknight's post and transcribed/verified them against the 11-page schematic package. Two of the three are in good shape and ready to compile for a modern GAL22V10:
  • decoder.PLD (U5) — complete ✅
  • RAM.PLD (U7) — complete ✅
The third is where I'm stuck:
  • RFSHCNTL.PLD (U6) — the timing and DTACK control PAL ⚠️
The specific problem:
The source techknight posted declares Device V7501cc (an AT750), and uses two buried register nodes:
Pinnode 29 = c1;
Pinnode 30 = c2;
These are internal flip-flops with no physical pin. The AT750 supports them — the GAL22V10 does not. As-written, this file will not compile for any currently available device.
What makes this interesting is that the schematic itself has this note in the revision block:
Revision B — 02/09/93 — Update Sleep Ckt., convert AT750 to 22V10
So a corrected Rev B version of RFSHCNTL.PLD was definitely written — it just wasn't in the files techknight had. The PAL itself isn't doing anything exotic: it's an 8-bit timing counter, a 2-bit AS cycle state machine, and a register that gates DTACK. Straightforward to rewrite if the timing parameters are known — but I don't want to guess those on a real machine.
What would help this — any one of these would do:
  1. Does anyone have the Rev B RFSHCNTL.PLD source — the version updated for GAL22V10?
  2. Does anyone have a working board they could pull U6 from with a chip reader (TL866, Wellon, etc.)? A raw fuse map is enough to work backwards from.
  3. Has anyone already done this conversion?
I'm not really sure about all this, working through it.... would love to get a working board for my Portable
Thanks.
techknight
140
138
North Carolina
Well I was gonna reply to your DM over on 68kmla but guess whats always down!
Anywho, I never got around to re-engineering the design to have those restocked at MacEffects because of the RAM chips being long since EOL, and now the CPLDs are EOL.
I did pick up enough chips recently from reclaimed boards to make a handful more to resell but thats it, i need to come up with a new design.
SuperSVGA
81
51
Yeah the TSOP/QFP RAM is crazy expensive compared to the BGA stuff, 8MB in a single BGA chip is only like $7 even right now, as opposed to $40 for 4x of those.
408
197
Are 8 MB BGA chips 5V or something else? The other limiting factor is finding 5V SRAM.
campbellashe
62
40
Asheville, NC
Reactions: trag and Garrett
408
197
Finally made my own 4MB card, next is the 4 or 8 MB card design that I'm working on. Fun project. I updated the project and cleaned it up a bit for a git depository. It worked for me on first assembly and was easy to program the CPLD with Tigard.
Did you ever find the Rev B RFSHCNTL.PLD source — the version updated for GAL22V10?
