Creating this thread to track USB-Serial adapters and cables that can be used to make a serial connection between a Classic Mac and a modern machine.
In case you haven't seen it:
Reconnaissance: Modern Diagnostics for Your Classic Mac
Windows hosts: both FTDI and Prolific chipsets work. Driver install is needed.
Small cheap adapter – $10
OIKWAN USB to RS232 Adapter with FTDI Chipset, USB to RS232 Male DB9 Serial Converter
Similar to above but with a cable – $13
OIKWAN USB to RS232, USB Serial Adapter with FTDI Chipset,USB 2.0 to Male DB9 Serial Cable
Short cable (NOTE: description says Prolific chipset but mine is FTDI)
StarTech.com 1-Port USB to RS232 DB9 Serial Adapter Cable - FTDI Chipset (ICUSB232SM3)
If you need multiple ports (me)
StarTech 4 Port USB to Serial RS232 Adapter - FTDI Chipset (ICUSB2324I)
I couldn't get this one to work at all
SABRENT USB 2.0 to Serial (9 Pin) DB 9 RS 232 Converter Cable, Prolific Chipset
Mini-DIN-8 cable - connector on one end and leads on the other - ready to connect to DB-9
Mini-8P Cable, Mini DIN 8 pin Male MD8 to Wire End Connecter Adapter Cable
Mini-DIN-8 cables – I've successfully cut these serial cables and attached DB-9 connectors.
6ft Apple Serial cable, MiniDin8 Male, 8 Conductor 10M3-04106 (eBay)
DB-9 (screw terminals, no housing)
Avanexpress DB9 Breakout Connector RS232 Serial 9 Pin Connector Db9 Terminal Female with Screw
DB-9 (screw terminals, with housing)
ANMBEST 4PCS DB9 Female Breakout Connector,DB9 Solderless RS232 D-SUB Serial to 9-pin Port Terminal Adapter Connector Breakout Board with Case Long Bolts Tail Pipe (Amazon)
DB-9 (solder type)
Oiyagai 10Pcs DB9 Female Connector Set, Solder Type, Plastic 9 Pins D-Sub Adapter with Hood for Serial Port (Amazon)
(Likely but unverified) Apple IIGS Serial & Null Modem Cable for use with ADTPro
(Unverified) 6ft DB9 Female to Mini DIN 8 Male Cable - Gray
Apple Macintosh Plus Peripheral Adapter M0199 / 590-0553-A (available from various eBay sellers)
uxcell 8P Mini Din Male to Female DB9 RS232 PLC Programming Cable (Amazon)
JSADZKJ RS232 DB9 to Mini DIN 8-Pin Serial Cable, DB9 9-Pin Male to Mini DIN 8-Pin Male Screw Terminal Adapter Cable DB9 to Mini DIN 8-Pin Audio Cable for Microphone Scanner Printer (Amazon)
USB Serial Adapters
Mac hosts: adapters with the FTDI chipset is preferable because no driver install is needed.Windows hosts: both FTDI and Prolific chipsets work. Driver install is needed.
Cable Parts
See the Connector Pinout ReferenceMini-DIN-8 cable - connector on one end and leads on the other - ready to connect to DB-9
DB-9 (solder type)
Pre-made Cable Options
(Likely but unverified) RetroFloppy Apple IIgs, IIc+, LC III null modem cable(Likely but unverified) Apple IIGS Serial & Null Modem Cable for use with ADTPro
AVOID (Miswired)
