My SE/30 has developped distorted sound in 2026
Mu0n
703
676
Quebec
This SE/30 has been logic board recapped around 2019, it was my 3rd or 4th ever soldering job and I did a passable job of it with tantalum caps.
Its analog board has yet to be done as well as the power supply. It's been a stable workhorse and I've even left it running for days uninterrupted for #MARCHintosh.
Here's a recording from Super Studio Session in 22 kHz, but running a Studio Session song of 6 channels:
Pay attention to how every instrument has this rough distorted feel.
Here's a recording from Studio Session (so, 11 kHz) running the same song, but from my Mac Plus:
Every instrument is immediately clearer.
Before you think this is a System 7.1 on the SE/30 vs a System 6.0.8 on the Plus issue, consider the following: on the SE/30, the sound becomes PRISTINE again if I use the headphone jack instead of relying on the internal speakers.
I know that if both the speaker and heaphone sound output are problematic, it points to a sound chip problem, but what does it mean when only the speaker quality is bad?
  • se30.mov
  • plus.mov
Mu0n
703
676
Quebec
Missing one-half of the waveform. Either the upper or lower transistor failed in the audio output stage, or you are missing the -12V.
ok, those are good avenues to test. -12V seems like the low hanging fruit, I'll check my external floppy drive port, I think?
How do I test these transistors? The sound chip is UE10, correct? This is what I have that I think is the most relevant schematic page for the SE/30
YMK
451
365
Q1 and Q2 form an emitter-follower output stage.
Check for the the +12/-12 supplies at each collector.
If the upper half of the output is distorted, replace Q1.
If the lower half is distorted, replace Q2.
Be aware, they are different parts.
Reactions: kaltree and JDW
Mu0n
703
676
Quebec
How do you propose to check for distortion? Send a pure sustained sine wave through the Sound Driver's 4-tone synth and check the output at each transitor on a scope, and look for sinus impurities?
YMK
451
365
A sine wave test would work.
Q1 and Q2 have their emitters and bases tied together, so the output is shared.
A failed transistor will be obvious; You'll be missing the upper or lower half of the output.
I'd replace both as a matter of course. They're cheap and used throughout many logic boards.
Reactions: Dave928
