Hello, new user here. Please let me know if I am posting in the correct area. I am not that experienced with classic Mac OS, so I may be making rookie errors.
I'm trying to get a Macintosh LC 475 running Mac OS 8.1 to communicate with a netatalk server. They talk, but there is a very long pause during copies to the server.
On an example copy of a ~4 Mbyte file to the server, speed is good for about 5 seconds, probably around 100-200 Kbyte/s, but then slows to a crawl, essentially pausing mid-copy.
It eventually will carry on and finish, but the overall speeds make using a floppy more viable. When I first tried copying a few tens of megabytes to the share, it (eventually) told me it would take three hours. I restarted netatalk to cause the client to error out, but the files that had made it up to that point, except the last file being copied, were intact.
What could be the cause of this long pause, and what can I reasonably do to try and make the mounted share more viable? Could we say whether the problem is on the client or on the server? Is there more information that would be useful for me to provide?
Server:
- netatalk 4.4.1 on a FreeBSD 15-RELEASE VM, with a 12 GB share
- This server was prepared expressly for this purpose, so I can change almost anything about it
- netatalk listens on a specific address (an alias which is a different L3 address from its main address)
Client:
- Macintosh LC 475, 20 Mibyte RAM, 512 Kibyte Video RAM, 120 Mbyte Quantum SCSI HDD
- Asante PDS card Ethernet (model not known) and 5.6.1 driver/extension (chosen based on TCP/IP CP OUI)
- Mac OS 8.1, clean install from CD after booting floppy and wiping boot drive
- Later, updated AppleShare to 3.8.3 but it only affected netatalk auth, not the pause
- Need to specify netatalk server address by IP address in Chooser
- Gets appropriate IP address via DHCP on same L3 network as the netatalk server
- Can ping, can use GetDownClassic (on local network at least)
- Also has an external 330 Mbyte CDC WREN drive attached (maybe older than the computer!), this is the copy source
Network:
- D-Link DGS-1100-05 Gigabit managed switch
- Macintosh LC 475's port on the switch set to 10 Mbit/half duplex
- D-Link has uplink to rest of network where netatalk host lives
- All cables tested to work at Gigabit Ethernet speeds previously on other hosts
- IPv4 network with no Mac-specific services running other than the netatalk server as above
Thank you!
Server:
Client:
Network:
Thank you!
