Hi all, first post here!
I have a Mac Classic that's making a loud sizzling/fryinng noise, but works fine otherwise. The noise disappears when I disconnect the logic board. The machine is 110v and the analog board is the 820-0525-A Hitachi version.
Repair background:
The machine seems to work fine, except for the noise which was present from the beginning. The Dead Mac Scrolls guide mentions the sizzling and mentions bad grounding, but I checked it and it seems fine.
Any ideas what I could try next?
I thought about using an old PC microphone and headphones to try to pinpoint the component that's making the noise, but maybe having a mic wired straight to my head, near high voltage might not be such a good idea
Thanks in advance!
Repair background:
- Fully cleaned and recapped logic and analog boards, except the RIFAs (the logic board had some cap leakage but no bad corrosion)
- Replaced CNY17G, TDA4605, DP3, DP4 diodes in an attempt to fix wobbly display and low/unstable voltage (didn't help initially)
- Flushed the PP1 voltage adjustment with contact cleaner and that fixed the display/voltage issues (voltage now snaps straight to 5v / 12v as as soon as I flip the switch - before it creeped up slowly and was very unstable)
- Reflowed all cracked & high stress joints and cleaned all contacts
Thanks in advance!
