Mac II Video glitch
blturner
38
19
Seattle, WA
benjaminturner.me
I've been running in circles attempting to diagnose some garbled text when something is highlighted on screen. At first I assumed it was a RAM issue because I had been reconnecting traces on the problem board, but I've now encountered the issue on two Mac II's and a IIx. Snooper and APD have not found any issues with RAM. I have two Toby NUBUS graphics card and an Apple Display Card 8*24 where text gets garbled. I've booted from a BlueSCSi and a floppy disk and it persists. It seems to only happen on 256 colors. Millions is fine. I'm using a Dell LCD display with a DB 15-pin->VGA adapter, maybe that's all it is? I only have LCD displays so it's difficult to rule that out as the culprit. I mostly want to confirm that this is not an issue on the logic board so I can move on with repairs.
259
327
Very interesting.
It isn't the LCD.
1. Does it happen every single time in 256 mode?
2. Is the scrambled text always scrambled the exact same way or does it look randomly scrambled differently each time?
blturner
38
19
Seattle, WA
benjaminturner.me
I think my initial diagnosis was incorrect, the scrambling is happening at 4, 16, and 256. I attempted to record the monitor changes to better illustrate what I'm seeing.
Here is the Toby card without the RAM expansion, only supports 16 colors:
Here is the Toby card with the RAM expansion and 256 colors:
It's hard to tell, but I think the scrambling does look the same each time.
259
327
And, it is only scrambling inverted text. That's a clue.
Have you tried booting with extensions disabled?
259
327
Try changing the highlight color in the Color control panel (?) to something like yellow.
blturner
38
19
Seattle, WA
benjaminturner.me
That's crazy. Definitely related to highlight.
What system version?
It's 7.1 from the Legacy Recovery CD image. I also have a 7.5 install on this SD card I booted from just now and the issue is there as well. Could it be the VGA adapter I have? That's the only common denominator besides the display and the BlueSCSI. I'd have to check again, but I don't think I've seen this issue on a IIci I had hooked up with this adapter (but different video card) and display during #MARCHintosh. o_O
blturner
38
19
Seattle, WA
benjaminturner.me
I took the Toby card and VGA adapter and put them in the IIci and there was no highlight glitching, so it must be something specific to the II(x). I have a 256k and 512k ROM, so I swapped the 256k with the 512k, but no difference.
259
327
I'm not giving up on this. I swear I've seen it before.
Based on Apple's ROM code, highlighting was really tricky and there were a lot of patches for it. Patches were stored in the System based on the ROM 'family" (128/512, Plus, II/IIx, IIfx/IIci/IIsi). To save space, when the System was installed it would ask if you wanted a version just for this machine or universal. If you choose just for this machine, then the patches for the other ROMs are not installed. Maybe the system versions you are using include the IIci patches but not the II/IIx patches.
259
327
If you post a copy of your drive image (whatever is the smallest that exhibits the symptoms), I'll try it on my Toby card and Mac II.
Reactions: blturner
blturner
38
19
Seattle, WA
benjaminturner.me
Oh interesting! I will do some more testing tonight. I have two partitions I've been testing with, one is Universal and the other, I believe, was machine-specific. So hopefully that is the culprit.
blturner
38
19
Seattle, WA
benjaminturner.me
Here are the ROM SIMMs I have:
I attempted to reinstall the system tonight a few times, but never got to where the highlight wasn't glitching. Do you think I should be installing the machine-specific software version like in the screenshot below or the "works on any macintosh family" version to get the right ROM patches? I tried wiping the image on the bluescsi i'm using and installing fresh systems of 6.08, 7.01, and 7.1 and they all had the glitch with highlighted text. Tomorrow I may try a completely new SD card to rule out any of the other disk images I have on this card, and I'll upload an image for you to try out.
I really appreciate the help working through the troubleshooting on this!
blturner
38
19
Seattle, WA
benjaminturner.me
I had time to look at this again last night. I borrowed a Floppy EMU from a friend and booted from the install disks for Systems 6 and 7. The scramble remains when booted from the floppy on anything other than black & white for grays or colors:
