Macintosh Portable M5126 - Battery problem - Good night :0)
Scouter3D
Hi,
my name is Tom and this is my first post in this forum. I run a small online homecomputermuseum site and i repair a lot of vintage computers.
Now, i am in the process of fixing a non working Macintosh Portable M5126 for a friend
After recapping and fixing 3 broken traces / Vias the mac greets me with a chime and boots a systemdisk from the diskdrive.
BUT: then i get the "no reserve battery power - good night" message imediatly after the system is bootet.
BTW: the battery is a new replacement one and gets charged from the mac and meassures around 6V, but the mac battery menuitem shows battery level at 0%
the small battery compartment switch is working and both buttons (reset and inerrupt) are working.
Without the powersupply the mac does not startup at all / or only 1 second...
Yes, it is possible that there are more bad VIAs
It would be great if someone could give me a hint where to search, or what to meassure (i can use my oscilloscope) ... to narrow down the search-area :0)
Cheers and many thanks in advance, TOM:0)
PS: Sorry for spelling mistakes, as my native tounge is german (i am from austria)
PSPS: is there a correct schematic for the M5126 somewhere?
Reactions: NullCipher1337
Scouter3D
Hi,
i just started meassuring around with the osci and i found that +5V is not +5V but 6.something with a lot of ripple... :0(
Cheers, TOM:0)
Scouter3D
I have watched all the videos from @techknight regarding mac portables, => very informative and a great help!!!!! Thanks!
In one video he removes a few of the smd chips and finds cap-rot beneath...
I thought the area looked fine, but decided to remove the resistor-array => and found at least one VIA completely gone...
Next step: patch it up and remove the other smd chips in the area...
Cheers, TOM:0)
Scouter3D
I have removed two more smd chips and found no more corroded traces... :0)
Find a picture attached for future reference of the traces under the chips... so you can check for continuity without removing the chips...
Red: Topside, Blue: Bottomside
Cheers, TOM:0)
NullCipher1337
10
6
Hi Scouter, did this fix the issue? I have no idea what this is until now, it's very cool though from the Wikipedia picture! How long does it last on battery?
Scouter3D
Hi and Eureka!
after soldering everything back and patching up the bad VIA the Portable has the correct voltages, recognizes the battery and its charging-level, boots from Floppydisk even without an external PSU attached... NICE :0)
Sadly, it will not boot from the BlueSCSI but that may be fried from the overvoltage? I guess the owner will try it with another one...
That´s it for today!
Cheers, TOM:0)
Scouter3D
You won´t believe it!
Now it also boots from BlueSCSI... The BlueSCSI was not fried from the overvoltage... NO! It was simply badly soldered from the original manufacturer => On Pin of the SDcard slot was not solderd at all! (I guess it was barely "touching" because it appears to have worked in the past) => a bit of solder and now it boots :0)
I am happy like a happy mac :0)
techknight
129
130
North Carolina
Yay! Good, it all worked out.
Even though its not your case, sometimes itll open a trace between the negative side of that 47UF cap over to a resistor on the right side at R208
Reactions: Scouter3D
