Need to emulate a 2.5" quantum 80 meg hard drive for 1992 Kodak DCS200 early DSLR camera.
Brin
12
Hello fellow Tinkerers, I collect and restore digital cameras, especially early ones. Kodak used a Quantum GO-Drive for the second series camera that was similar to the Apple Laptops drive. Including beating them self's to death sticking and UN-sticking them self from the dead stops. I've tried a v2 and a 25 pin external Blue SCSI's. Also a Zulu SCSI v1.1. None have done more than showed LED activity. I arrived late to the recent Antique Computer show and only just caught Eric E. packing up. Differences I've noted are, early DOS Fat file structure {16 or earlier). Program for accessing it's raw files ran on DOS 6 and Windows 3.1. The camera powered up the drive and waited for spin up to transfer files. possible "at speed" hand shake or just time delay. DB 25 external took any size "Hitchhiker" external drive and nullified presence of internal drive in camera. Power and SCSI ID supplied by camera. All 40 ribbon wires connected, no telling if used. Eric mention a breakout tester or such to check signals "?". Does anyone know of one? Or a source for a male and female 2mm spacing IDC connectors. Thanks for everyone's hard work I at least can use the units for my early Apples.
Androda
Emeritus Board Member
542
608
USA, Western
androda.work
As an overall note, those pictures are very blurry. It's hard to see details in them.
Just to restate, you have tried a BlueSCSI V2, a DB25 BlueSCSI (which version? V1 or V2?), and a Zulu and none of them work? There could be several things going on:
* this might be trying to use custom vendor commands which we don't have implemented
* maybe the "quirks" mode is set to something the camera doesn't understand (this requires using an bluescsi.ini file to change, which can be generated here)
* it's also possible that the camera's SCSI implementation is "just different" enough to cause issues with the SD to SCSI solutions
As for the SCSI blinky light device, that's here. It is *not* helpful for most users, because all it does is show the raw SCSI bus state (which usually transitions around faster than you can see). Generally speaking it's only helpful if the bus gets "stuck" in a bad state, so it's mostly for developers or people that need a plug adapter board (blinky lights are a fun extra).
Brin
12
Thank you both, and especially Eric and his associate who I discovered weren't trying to leave but to shop before everyone packet up. I feel like such a nerd. Led board shows not currently available, I'll take one the minute it's in stock. Or do you need it paid first for funds?
Androda
542
608
USA, Western
androda.work
There's one adapter board left as a kit, if you feel like assembling it. I have more of these on the way from the PCB manufacturer, and will then have some assembled available.
Brin
12
Thanks, received the SCSI adapter board. A nice unit. I was able to access a drive image as a device on two Adaptec boards in two pcs. An ISA version in a pentium 2 windows 3.14 that has the camera twain software and Twain driver. Then was able to Format FAT16 to it on a Adaptec PCI in a IBM p3 server under the cards utilities. I pasted a TIF image onto it under XP Pro. Also confirmed function of Blue SCSI V2-2022_11b, a BlueSCSI DB25 1.1-a, and a ZuluSCSI V1.1 for Laptops Rev 2022a. So I will see what response I get attached to one of the Cameras. Gotta cleanup my desk etc. "If you bury one project with another one You just might be a Pencil Neck".
Brin
12
Hi, yes I did. I never got a chance to do better photos and list the steps. Where are you at with yours. Did you separate the camera from the back. Watch out for corrosion holding either battery of camera or back unit in, they are fragile. if it turns on do you get an error or hear the drive run inside? I'm assuming you have a DCS200. I can help with most of the other DCS models too. As far as software and drivers i have those too. Don't know best way to send them to you.
Baseophobia
I have the DCS 200 same as you. I had the camera completely working then the drive died. I tried removing the internal drive and just using an external bluescsi. that didn't work and kept showing me E2 so now I'm trying an internal blue scsi. did this end up working for you?
Brin
12
Yea the sad thing is its two rubber spots that the arm hits getting sticky that kills the hard drives. I got the laptop sccsi from Blue Scsi. I found I had to back flash it to an earlier version. this let me call its scsi address that was blocked on newer Flash versions . Ill dig back in my notes. I'll post again soon as Ive got time this weekend. You might find it in that chat I had with Erick. I know one thing You'll love. It's so fast compared to the drive. I've been working on Battery repair pieces for both Battery holders. be careful of A batteries sometimes are taller (?!!!). they strain the plastic. Also only use Nikon Flashes, I zapped a DCS420 with a cheep (single contact on bottom of flash). They put a spike across the cameras transistor. I'll get back to you soon.
Baseophobia
Ok good news actually!! I got it working with the laptop bluescsi today!! it was plug and play. I just created an 80mb disk image set to scsi id 0 in disk jockey and set the jumper on the bluescsi to be terminated! for batteries I have some recharge-able aa's I've been using. Mine was corroded pretty bad when i got it but i got that cleaned up fairly quickly! I'm not planning to use a flash on it but if I do I have a nikon speedlight so I'll make sure to only use it with this camera. I also have a spare N8008s as luck would have it. And yeah you're right it's WAY faster with bluescsi than an hdd!
Brin
12
Cool. Now how about getting your pics? Apple or Pc? I used Aldus photo styler on Dos with an adaptec card. I still need a 25db male to female pin terminator. You have to imagine the camera as its own LUN on the scsi. That was an early scsi application. There is a twain driver for the Kodak. I have most of this or links. The files are a Kodak raw file.
Baseophobia
I use a biege apple g3 desktop with photoshop 2.5 and the twain driver! it works like a charm the only strange thing is taking the jpegs from phoshop 2.5 to a modern pc they can't be opened by anything unless i run them through a jpeg to jpg file converter. Is there a way to take the raw files from the kodak and convert them on a modern pc and skip the jpeg nonsense that you know of?
Brin
12
I open mine in "Shotwell" . It is an open source Linux program. I haven't worked with photoshop. It's possible the layers thing needs to be de-Adobe'd. Or Windows is being a bee-och.
