ESFloppy - An Open-Source Floppy Emulator For Mac, Lisa, Apple II, and Apple ///
AlexTheCat123
14
32
Columbia, SC
If you're familiar with my LisaFPGA project, you may know that it included an onboard ESP32-based Sony 400K/800K floppy emulator. But after I finished implementing the minimal floppy emulation needed to satisfy the Lisa, I figured it might be fun to try and extend it to support other Apple machines and drive types as well. And as you'll see, I was quite successful!
If you want a (rather long) video demo of everything the device can do, you can go watch that here:
The board can currently emulate:
- Sony 400K/800K drives for both Mac and Lisa.
- Dual Twiggy drives for the Lisa; this is the only emulator I know of that can do this.
- Up to 4 simultaneous Hard Disk 20 drives of any capacity for the Mac; it supports Apple Partition Map images too, so a BlueSCSI image will mount as well.
- Dual Disk II emulation for the Apple II.
- Up to 4 UniDisk 3.5" SmartPort floppy drives on compatible Apple II models.
- Up to 4 SmartPort hard drives on compatible Apple II models.
- Up to 1 (internal) or 3 (external) Disk /// drives on the Apple ///.
In Sony 400K/800K mode, ESFloppy has the same neat feature that Floppy Emu has where you can select a .sit, .hqx, or .bin archive on your SD card, and it'll automatically create a container disk image around it in RAM, allowing you to easily transfer files to a Mac without needing to manually copy them into disk images.
I'm hoping to do 1.44MB emulation at some point in the future too. There's no technical challenge preventing it from being done; it's just that MFM is a completely different paradigm from all of the other GCR-based protocols, so that's why I haven't tackled it yet.
The hardware is really simple, and simplicity means that it's really cheap! The only chip on the board is an ESP32-S3, and pretty much everything else is just passives. No CPLDs or anything like that. The dual-core ESP32 is able to split the workload in a similar way to a CPLD-based system like the Floppy Emu by dedicating one core to the higher-level UI and SD card tasks, and dedicating the other core to the low-level disk I/O.
I used my rather mediocre CAD skills to design a 3D-printable case for it, but I'm working with someone to design a really nice frosted acrylic case like what Floppy Emu has. Hopefully that turns out well!
As with all of my projects, ESFloppy will be fully open-source on my GitHub page, and I'll also be selling them through MacEffects for anyone who just wants to buy one. If you think you might want to buy one, fill out this form so that I can judge demand and figure out how many to order. Everything is essentially completely done and tested at this point, so it's just a matter of ordering them and doing some final testing. I've been dedicating pretty much all of my time outside of school to this since early July, and it's nice to finally be done!
techknight
133
132
North Carolina
Oh heck YES! Love it
Ron's Computer Videos
236
318
Thank you, Alex!
Eric's Edge
98
Awesomesauce!
2,336
Amazing work! Love the no fragmentation issues and all the drive features you were able to cram into this.
In the video you mention 1.44 will likely be later. Is there any hardware that would need adjusting or is it just the new protocol?
Looking forward to using these on my Apple //c and Mac’s!
Wanna have a go at reverse engineering an IWM / SWIM replacement? :D
Reactions: jcm-1
AlexTheCat123
14
32
Columbia, SC
Thanks! Yeah, allowing fragmentation was very important to me because it was always so annoying to have to make your files contiguous on Floppy Emu. It's too slow to have to read the FAT on every SD card access (which is why Floppy Emu refuses non-contiguous files), so I use an approach where I walk the FAT when the image first opens and build a table of fragments in RAM, and then I can use that at runtime to figure out where each fragment sits instead of having to do a FAT read every single time I access the card.
No additional hardware would be needed; it would just be a software change to add the MFM protocol. I don't really know much about how MFM works, so that's going to be quite a learning experience!
I don't know about the SWIM, but hasn't somebody already made a CPLD-based IWM replacement?
Reactions: eric
stepleton
31
17
I think it's quite a bit simpler than GCR, especially 13-sector Apple II GCR if you implemented that.
