Hello folks,
I've been doing some experimenting with QuickDraw this week, trying to get NuBus video on my Centris 650 running as fast as I can, but I don't have any other fast Nubus Cards beyond my PrecisionColor to compare with.
Does anyone have...
1. Some time and enthusiasm.
2. A faster SuperMac Thunder, Radius Thunder or similar late model, high end NuBus, video card.
3. A Quadra of some description.
If so, would you be willing to run Norton System Info's video benchmark suite and share the results? Just a photo of the detailed breakdown (so that it shows the individual scores for each of the tests like text and scrolling etc).
I'm using Mac OS 7.5.3 and Norton System Info 3.2?? or so - the version that uses the Quadra 700 as a baseline. (I'll check and update this post once the huge long MacBench test I'm running finishes). Run the benchmarks at 8bit, 640x480 with appletalk off for consistency.
Make sure you include...
Computer model
CPU Clock Speed
Nubus Video card model
System version
Norton System Info version (double check that it is the same as mine, because the same computer's scores drift between versions - even when you correct for the different baseline computers).
Does anyone have...
Computer model
CPU Clock Speed
System version
