MacTilt
KennyPowers
359
396
Well, I contacted Ergotron...we'll see where that goes. I did set my Classic on the stand, and the foot pattern is the same:
So, the "conversion" kit is likely just a different mounting plate or riser that allows the Classic's bottom air vent to breath, along with maybe a different retention mechanism since the Classic's side vents are different. I did find this picture on the "history" section of Ergotron's site that shows a different mounting plate that appears to not obstruct a Classic's bottom vent:
In 1985, Ergrotron advertised the MacTilt with a time-lapsed photograph demonstrating the flexibility the compact Macs gain with the MacTilt. :)
Paralel
139
58
I tried, but no luck. Customer service would not connect me to their engineers. Their response was terse like "We use to carry these mounts and it was very popular at the time, but unfortunately we no longer carry these as these are not common monitors. Sorry I couldn't be more of assistance on this one. Is there anything else I can assist with in the meantime?"
That is really cool. I guess sometimes people who now work for those companies' customer care nowdays just dont really care and not very helpful.
I find that very disappointing. I'll have to see if any of the e-mail addresses I have for people at the company still work and let them know that their customer service is anything but.
KennyPowers
359
396
I just contacted them through their main customer support email...got a ticket number automatically assigned, etc. If you have any more "direct" contact info, please let me know!
495
LOL! I always thought of stuff like that as MASSIVE overkill/ludicrous over-engineering to achieve what was a simple solution to a simple problem.
When my SE was wrecking my neck in the day it was brand new, I just bent a piece of 1/4" Plexi into a flopped over, roughly "Z" profile which angled the front up to an ergonomically correct angle. Lift was about 1.5" at the front, a solid angled base then had a low lip upturn at the back which let gravity do its thing in terms of stabilization. ;)
KennyPowers
359
396
Thank you very much for contacting Ergotron. Unfortunately, we no longer have parts for the MacTilt and unable to provide any support for this product.
Lifetime warranty is subject to parts and equivalent products availability. Unfortunately, we exhausted both options for this product.
Oh well :(
495
I have been considering 3D printing a solution similar to Mac Tilt for my SE and SE/30. Looks like it shouldn't be difficult to do that. Kensington did have another one that is a simple shelf to put keyboard under.
Perhaps we can create 3D printed versions of the shelf and the tilt for compact Macs? :)
Love it, though I'd want to see provision for a metal frame insert incorporated. Front bezel looks perfect for SD slot and its HDD activity LED.
764
Only kinda related to the MacTilt, but I found this with it in the basement too:
It's a monitor stand for the IIgs and IIc with space for two 3.5" drives underneath when used with a IIgs. Apparently there were removable angled risers for it to allow putting a IIc under it too...not sure how you'd access the drive on a IIc while it was under this thing though. I pulled out my other IIgs to mock it up:
I picked up one of the Apple Iic stand and never could figure out what it was used for, as I don't think the Iic fit under it well, or maybe I couldn't figure out the inaccessibility of the disk issue.
Here's the angled risers:
iantm
187
86
Great Lakes
Assuming you still have the Mac Tilt, would you mind taking photos and/or measurements of the metal base? I acquired one with a metal plate that's too small for some reason. Everything else about it is fine, but the holes simply do not line up. It's my fault for not being more careful… but at least it's a surmountable problem. I just need to know the dimensions and spacing of the real thing.
EDIT: If I'm to believe the AIs, apparently this is just a different base for a different device (like an A26014 monitor). So I guess it's legit, but not for an SE. I might try and print an adapter for the top..
KennyPowers
359
396
Hope these photos help...batteries were dead in my digital calipers :rolleyes: You can probably just get the measurements for the "foot holes" from the mac itself. If anything, these should give you an idea of how far to offset where the plate attaches to the base. All of the other measurements are pretty obvious.
PXL_20261116_183911267.jpg PXL_20261116_184023032.jpg PXL_20261116_184149007.jpg PXL_20261116_184220868.jpg PXL_20261116_184240046.jpg PXL_20261116_184301827.jpg PXL_20261116_184317550.jpgPXL_20261116_184336781.jpg
iantm
187
86
Great Lakes
Success!
Have you ever done anything to the mechanism to make it glide more smoothly? Mine is really, really stiff. It rotates just fine, but tilting is nearly impossible without both hands.
iantm
187
86
Great Lakes
I figured that might help, I'm not 100% sure where to apply it or whether or not it requires any kind of disassembly. I'll look for some likely spots and avoid taking anything apart to start.
iantm
187
86
Great Lakes
It did end up requiring disassembly, but it's really straightforward in its design. The old grease just wasn't working any longer. One side had completely seized up and I had to slam it with a mallet to get it to move.
But with an IPA clean and fresh grease, it's night and day. Plus you can adjust the torque with the side screws to release some of the pressure on the metal "brake pads".
615
It did end up requireing disassembly, but it's really straightforward in its design. The old grease just wasn't working any long. With an IPA clean and fresh grease, it's night and day. Plus you can adjust the torque with the side screws to release some of the pressure on the metal "brake pads".
I was a bit surprised to see an "automotive" cross spider from a universal joint in the middle of a computer accessory! o_O
  • Haha
Reactions: iantm
