Issue with the power button on a Cube
indibil
40
14
rosysumenteinquieta.blogspot.com
Hello.
A friend of mine has a Cube that recently stopped booting. He brought it to me, and after thoroughly cleaning the motherboard and the VRM (both were very dirty), the Cube now works perfectly. It has a Gigadesigns VRM installed, but it works just as well with the original one—which he still has—as it does with the Gigadesigns unit.
However, there is one issue: as soon as it’s plugged into a power source, the white power LED flashes and then stays lit, but the Cube itself doesn’t turn on. Pressing the power button doesn’t start it either. The only way I can turn it on is by using the power key on an iMac G3 keyboard.
I swapped the power button panel with the one from my own Cube, and it works perfectly, so the fault lies within the button circuit itself. I’ve checked the solder joints and the traces, but the problem persists.
Is anyone familiar with this issue? Or is there a possible solution?
indibil
40
14
If I recall, it has to do with the grounding. Here are a couple other threads elsewhere:
Macrumors and TonyMac86
Thanks, I was already aware of those links.
I’ve checked and secured the ground connection, but that doesn’t seem to be the issue. There is an IC (U200) marked "A00B" that gives me different readings compared to the one in my Cube; it has 5 pins—perhaps it’s an op-amp—but I’m not sure what part number I could use to replace it.
