Graziano
Hello,
I am using a "C" version, and the scanning process is too fast.
I scan the film reels without using any zoom; by raising my 12mm macro lens just 5.2mm, I achieve a full frame without needing to zoom in.
To avoid the risk of jitter and the need for multiple passes over the film, it would be ideal to reduce the speed to one frame per second instead of two.
Is this possible by modifying the firmware?
melw
53
80
Type D - FW 295​
  • 24 FPS support. In recording mode it's possible to toggle now between 16/18/24 frames per second.
  • Card only mode. Build and deploy with -Card to generate FW96658T.BIN - this build never flashes anything on the device, it is executed at boot as long as the bin file is kept on the SD card.
  • Type probe. Experimental Type probe that launches in Card mode and attempts to detect which firmware or device type you're running.
For permanent flash:
  • FWDV280.BIN: put this on the card together with empty folder NVTDELFW
For runnings from the card:
  • FW96658T.BIN: the firmware will boot as long as it's found from the card. Once removed, the previous / permanently stored firmware will be used instead
For type probe:
  • See thread post #833
The source, the user guide and the changelog are on GitHub: https://github.com/melw/reels-type-d
  • FW96658T.BIN
  • FWDV280.BIN
thilosde
Type D - FW 295​
For type probe:
Ich denke dieses FW96658T.BIN ist nicht das richtige.
