Transplant G4 hardware to a PC case
alex_santos
44
23
buriedbits.org
I have a fully working Power Mac G4 tower, but for various reasons I'm looking to get rid of the original case while keeping the hardware.
I realise the G4 motherboard isn't a standard ATX form factor, so fitting it into a modern PC case won't necessarily be straightforward.
Has anyone here successfully transplanted a Power Mac G4 motherboard and its components into a modern PC case? I'd be interested in hearing about any such projects, particularly what modifications were needed.
Oelmuvun
21
20
If you have a MDD, don't bother, refurb/mod your case instead. Motherboard layout is some bastardized BTX-like layout and you'll need a bunch of custom fabbing.
For QS, DA, GBE, Sawtooth, etc:
You'll need a case with removable standoffs so you can drill new holes to add your own. I used to like to punch some holes and use nuts on the back of the standoffs to allow fine tuning to make sure the board was positioned for best PCI slot alignment. If a person was ambitious and very precise they could use rivnuts or whatever brand of self-riveting-threaded-insert.
Depending on the board and case you likely also need to do some trimming on the back panel at the top of the slots to clear your board's ports. Of course you'll need to make your own I/O shield if you care about that.
For power supply you either use what you have from the G4 or use an ATX extension to wire an adapter. Note that models requiring 28v or whatever it is for Firewire and ADC can be run without a full 28v if I recall correctly... if you aren't using those. Just make sure your standby rail is hooked up.
Aside from that everything else is just normal PC building. For power/reset/led you can rewire a small connector if you don't want to try to mount your existing front panel board in the new case. I don't really remember anymore, but I think Apple ganged the grounds together in one pin as opposed to PC cases having separate per each button/led.
There used to be articles on xlr8yourmac, MacMod, Applefritter, etc but I think most of that is only in wayback machine these days.
alex_santos
44
23
buriedbits.org
Thanks for the reply. I'll check out those sites on the Wayback Machine. Hopefully, I'll find a guide or a post from someone who has attempted this before and shared some useful tips.
The reason for this transplant is that the inner metal chassis was bent out of shape years ago during shipping, causing one of the upper front support arms to shatter. Rather than simply discard the hardware, I thought this could be a fun project.
My intention is to transplant all the original hardware into a new enclosure, keeping everything original, including the power supply.
I believe there may be a market for the original plastic components, so I just need to restore the glass-like shine to the outer plastic doors before deciding what to do with them. I've tried hand-buffing them and the results are already great, but I'll use a machine polisher at low speed to finish the job without overdoing it, as it takes quite a bit of elbow grease.
It's still a fun little computer, even though I have other G4 towers.
As for the exact model, I believe it's one of these two, although I can't remember which:
  • Power Mac G4 PCI Graphics
  • Power Mac G4 AGP Graphics (Sawtooth)
Oelmuvun
21
20
some useful tips.
After removing the ATX case's standoffs(if it came with any installed), populate your PCI and/or AGP slots. At a minimum the top and bottom, but more if you have and/or feel like it because some cards have weird or bent brackets. Then with the board&cards sat loosely into the case observe if the Mac's rear ports are blocked or not and clearance as needed. Once your rear I/O fits nicely, secure the expansion cards to the case and eyeball&feel where the motherboard wants to sit and you can start marking where the new standoffs will go. It probably doesn't hurt to use a standoff-thickness spacer while aligning things, couple layers of cardboard, stick-on rubber footpads, chunk cut off an eraser, etc can be nice as they won't scratch the underside of the motherboard and are removable. If you are only using a couple cards for alignment and the board is sitting askew try different cards or adding more, you are trying to find a middleground where the board is square in the case, but the cards aren't strained... in a world where card brackets are dumb and PC cases might be wonky.
Marking the case's motherboard tray is fairly straightforward with a pencil or marker being mindful that you don't want to shift the board between holes and your holes should be even and consistent with each other. Consistent marking is especially important near the edges where case structure might get in the way. Fancy people using threaded inserts might put the motherboard tray against a block of wood and use a centre-hole punch to espablish a reference hole, then base everything else on that since the board won't shift much between the expansion cards and one established hole. It depends how much effort you want to put in.
Either way just make sure you centre punch before drilling so the bit doesn't walk off when starting. And use a sharp good quality drill bit.
Once you start handling and comparing parts it's all going to come together, it's actually really simple. Just take your time.
497
Drilling out ATX standoffs from the bottom side of the case is very easy. Once you've positioned you board, mark and install a single standoff. Then repeat for a second. From there it is not going to be moving at all. Mark drill and install the rest of the G4 standoffs and have fun!.
