Why to be careful with acidic flux - IIsi logic board
JeffC
149
92
Seattle, WA
I recently picked up an IIsi off the local classifieds as a project, knowing it (and the PSU) will need a recap. Someone had already done the 50mhz oscillator upgrade, so that was a plus - until I cleaned the board and started inspecting it. When I turned it over I saw corrosion around the pins of the oscillator, the rest of the board is spotless. I used a q-tip and IPA to clean the corrosion off and was dismayed by what I saw. Whoever did the upgrade had no idea what they were doing, it looks to me like they probably left corrosive flux on the board and it damaged the PCB, as seen in the attached photos.
I'm hoping the board is still ok. I got out the Bomarc schematic and used my meter to check continuity on the three pins (the fourth doesn't go anywhere), and it looks ok. One goes to power, one to ground, and one to pin 107 on the MDU. I'm hoping that no corrosion worked its way further into the board and affected any of the other layers. I'm inclined to just leave it alone, I don't want to cause any further damage by removing the oscillator for inspection.
Sometimes you learn a lesson the hard way, even if it's through someone else's actions!
croissantking
140
66
I wonder if the damage to the solder mask is corrosive flux, or just heavy handedness with a soldering iron?
I’ll take your word for it though and assume the solder mask had bubbled up or something, it would be interesting to see a before pic.
The damage looks to be cosmetic so a bit of UV solder mask would tidy that up. The joints should also be reflowed.
JeffC
149
92
Seattle, WA
Four years on, with more experience under my belt, I do think it was likely heavy handedness with an iron. Having done the same mod on another IIsi board, I found that pin is tricky and takes some finesse.
croissantking
140
66
I’ve done that mod too. It’s difficult on at least one pin because the ground plane wicks away the heat. I think the previous owner must have struggled quite a bit. Given the way the joints looked, I wonder if they used very much flux at all.
danielsmith
The ground-plane pin is the usual culprit, not necessarily excess flux—no-clean flux can leave almost no residue. I wouldn’t twist a soldered oscillator off; that’s a good way to lift pads. Preheating the board and using hot air (or a larger tip and a little low-melt alloy on that pin) is gentler. UV mask over the cosmetic damage and reflowing the joints sounds right.
