Turning the Freescale PowerQUICC SoCs into a Mac
BBenchoff
Ay all, I've had the idea of turning the Freescale PowerQUICC SoCs into a New World Mac. This covers the MPC83xx family of chips, which are PowerPC 603e chips, with an integrated memory controller, USB, and Ethernet. These are 20 year old chips meant for routers and other networking equipment.
All of this works because I built a 'MacIO chip on an FPGA'. I'm calling it Salesforce to keep the 'transit center code name' thing going, but mostly for the lulz:
I've had this idea for a while, but it's only recently that I found a Freescale dev board with one of these MPC83xx chips. I found that eBay listing in August. From there, the build was a little like the "OS 9 on a Wii" builds, where I get the Open Firmware on the board, and write a trap for all the exceptions, and have a monitor that patches all those exceptions. This _works_ because OS 9 is shockingly hackable.
From there, I wanted to see if it was possible to create hardware for this monitor/trap/exception hack. I bought a cheap FPGA on a PCI card meant for CNC motor controllers. That was a small FPGA, but it could be programmed to implement parts of the MacIO and System Controller functionality in hardware.
All of this works. It's a mac. AirPort works. It's kinda amazing. I wrote all of this up on my blog.
I'm not releasing all of this quite yet, because this is really only the beginning of a project I have in mind. Everything will be public eventually, but you're not going to want this Salesforce card.
demik
Really nice. Does that project includes soldering chips with around 516 BGA balls ? :p
It's a shame that (as far as I understand, might be wrong) it's not possible to use e5500/e6600 based stuff for this
Melkhior
119
72
I know this is pedantic, but aren't the MPC82xx the 603e, and the MPC83xx are e300? Very similar in practice but it makes a difference when you look for them at Mouser :)
Both family are EOL, but are still orderable for the moment...
That board as an Artix-7; not sure which one, but even the XC7A15t are pretty decent FPGA alread compared to the really entry-level stuff! That thing can be pushed to output HDMI in Full HD - same family as the one I have in my FPGA-based designs.
Very nice!
If you're planning a full-custom design with SoC + FPGA, it looks like it's going to be a complex and expensive job. Those Artix-7 need at least a 6-layers board (and are really meant for 8+). The PowerQUICC II SoC available on Mouser are in the 500-700 balls range, so similar to mid-range packages for the Artix-7. Both of them on the same board is going to be quite a complex PCB to figure out!
Looking forward to the result :)
BBenchoff
It's assembled through JLCPCB/LCSC. Life is too short to solder BGAs. It's also cheaper, if you value your time at anything above zero dollars an hour.
As far as those e5500/Book E chips are concerned, the main issue is memory mapping. Book E chips have software TLB entries; NanoKernel expects BAT registers and such. NanoKernel also expects fixed interrupt addresses, and the Book E chips use programmable vector registers.
Then there's the issue that NanoKernel reads the processor version number and only accepts what it knows. The e300 is a 603e and falls through to something in the 7450 family, which NanoKernel knows about.
I'm not saying it's impossible, but I don't want to figure that out.
The real cool thing would be the e600 chips; the MPC8641, MPC8640 and MPC8610 are basically G4 chips and they're in NanoKernel. It could be possible to build a ~1GHz G4 version of this, but I couldn't find a relevant dev board to test. It was only luck that I found the e300 version. I have eBay searches set for an e600 board, so nobody bid on them until I tell you to.
Yeah you're probably right on the 82xx vs 83xx. It's an e300, which is basically a 603e. six of one or something like that.
The routing is really not that bad. 2-layer board have two layers of routing. 4 layer board still only have 2 layers of routing. An 8 layer board is only 4 layers of routing. The only real risk here is being able to successfully capture the Freescale reference designs and implement them on a board of my own.
