Mac Plus display too wide issue ↔️ [SOLVED]
AndyDiags
94
167
Hi All,
I got a Mac Plus which was in pretty bad condition. The previous owner was trying to fixed it, but was looking in all the wrong places. I managed to mostly restore it, but one final issue, the screen is extremely stretched. Has anyone seen this, or has any suggestions?
Here is a side by side comparison of the stretched screen vs a regular screen:
As you can see, the screen is about 2x stretched. I tested the inductance on L2 and it matches that of a working board. Adjusting the pot on L2 doesn't seem to have an affect on the width.
One hint seems to be when I turn the machine on, for the first several seconds, the bulb at NE2 lights bright, which is not expected. According this, the bulb indicates there's a power surge at J2-9, the CRT cathode, but as I mentioned, only for the several couple seconds. Not sure if this is related to the width issue, or something seperate.
About the Mac Plus. It's beige (not platinum) color, so it's one of the very early ones . Has "Not for resale" graffiti on the side :LOL:
The logic board is a Rev D, so not the original. Someone did a very poor job of replacing one of the ICs into a socketed one (no flux, scratches everywhere, and a jumper wire). The logic board ended up having bad ram, I replaced the ram and verified it works in a separate Mac Plus.
The analog board on the other hand has had some serious work done to it. Date code is week 29, 1986, so it does seem to be the original. However the flyback seems to have been very cleanly replaced to a 157-0042C. U1 and U2 have also been pulled and replaced with socketed chips. But capacitor at C1 was still the original! When I first booted, I had a 5cm tall vertical on the screen. Upon further inspection, C1 was leaked and L2 had cold soldier. So someone went though the trouble of replacing the flyback and 2 ICs (as well as who knows what else), but never check for cold solder at L2, the most common failure on these. Probably pre-internet era repair. Replacing C1 and fixing the cold soldier I get the double width screen, which is where I'm at right now.
I've ordered the remaining replacement capacitors, but I doubt it will fix the width issue as other capacitors look ok. Anyone have any additional suggestions as I wait for the parts? I checked most of the components in place against a working board, everything seems to be in line so far. I've also ordered the two replacement ICs as I don't trust the ones that were put in since they're already socketed so an easy replacement test.
Reactions: Kai Robinson
Daniel Hansen
181
142
Nice work getting this machine restored! It's always an interesting journey...
I honestly think there's nothing to suggest until those caps are replaced and you see whether or not the issue is resolved - and you know you're working on a good baseline. I'm... 66% sure the caps will solve this. Maybe even 70%.
AndyDiags
94
167
Did you already try cleaning the pot with contact cleaner?
I reflowed the connector at L2. The component itself is very clean and no spillage onto it from the C1 capacitor. Not sure if contact cleaner could provide any additional help. I also verified the inductance against a working board and have values are equal. Later on I may just try swapping out L2.
Mouser parts just arrived, so I may get the capacitors replaced today.
Reactions: Daniel Hansen
AndyDiags
94
167
Fixed! Full recap resolved the issue!
It's kinda odd because the board has been already recapped once, but perhaps a long time ago. I think they also missed a couple caps. I did some additional reflows, so that also could've helped.
Along the way I also noticed the ROM on the logic board was going bad. I already previously replaced one of the ROM chips as it was completely dead, this second one was failing to boot about half the time with sad Mac.
AndyDiags
94
167
Issue came back today after hot gluing the components down. I noticed that moving the analog board with a pen would result in flickers and issues partially going way. This helped narrowed it down to cold solder joints.
From a distance it's kind of hard to notice....
But once you really zoom in, issue becomes apparent.
Not sure how I missed this one. Reflowed and purring like a kitten now. Lesson learned, double check for cold joints on all the analog board connectors even if they look fine.
From now on I'll make sure to give the analog board a good wiggle while it's running to make sure there's no flickering or any funny business.
