All about Apple PC 5.25" Drive (A9M0110)
slomacuser
143
The Apple PC 5.25 Drive may be used with a Macintosh® SE or Macintosh II to transfer data between 5.25-inch MS-DOS®-formatted disks and 3.5-inch Macintosh-formatted disks.
What you need to use it:
• A file transfer program such as Apple File Exchange.
• One of the following expansion cards:
- Macintosh SE-Bus PC Card, the MS-DOS disk drive controller for the Macintosh SE.
- Macintosh II PC Card, the MS-DOS disk drive controller for the Macintosh II.
- A third-party expansion card that is designed to operate with the Apple PC 5.25 Drive.
According to Apple, the drive and controller cards are not compatible with Macs with FDHD ROMs. source
Available Documents:
- Apple service manual
- Technical procedures
- PC 5.25 drive Product info
- Macintosh II PC drive card product info
- Macintosh SE-bus PC drive card product info
- Macworld February 1988 - Review
Missing:
- Apple PC Drive 5.25 Owners manual pic
Testing the card:
The MacTest™ SE and MacTest™ II programs test an Apple PC 5.25 Drive and an Apple disk drive controller card at the same time. If the system you are testing uses a non-Apple disk drive controller card, replace it with an Apple card before testing.
CAUTION: Do not install more than one Macintosh II PC Card in the Macintosh II. The power supply was not designed for two of these cards and could be damaged.
  • Apple_PC_5.25_Disk_Drive_Service_Guide.pdf
  • Apple_PC_5.25_Drive_Technical_Procedures.pdf
  • apple-pc-5.25-drive-8806.pdf
  • macintosh-ii-pc-drive-card-8806.pdf
  • macintosh-se-bus-pc-drive-card-8904.pdf
  • MacWorld February 1988.pdf
slomacuser
143
My own testing.
Macintosh SE, 4 MB, 20 HD, System 6.0.5, PC card, PC disk drive
- Apple File Exchange - WORKS - Utilities disk #2
- DOS Mounter 4.1 - WORKS
- DOS Mounter Plus 4.0 - system errors
- PC Soft 2.5 - does not recognise the drives
Macintosh SE, 4 MB, 20 HD, System 7.0.1, PC card, PC disk drive
- DOS Mounter 4.0 - system errors
Macintosh IIci, 16 MB, 500 HD, System 6.0.5, PC card, PC disk drive
- PC Soft 1.3 - WORKS
- DOS Mounter 4.1 - system errors
- DOS Mounter 1.2 - needs personalization (needs original disk)
- DOS Mounter 3.0 - needs personalization (needs original disk)
- AccessPC 2.0 - does not recognise the drive
278231837_10229131236605750_2040302969229100275_n.jpg 278234157_10229131236725753_2642056689464279776_n.jpg 278234314_10229131236805755_1139017508679065167_n.jpg 278256604_10229131236525748_260677093425242030_n.jpg 278263676_10229131235445721_2873496839116256466_n.jpg IMG_4820.jpg
Reactions: RetroTheory
RetroTheory
90
161
Here are a few shots one with a DOS formatted floppy mounted in finder with Dos Mounter
Formatting a bootable 5.25" floppy from SoftPC
Booting SoftPC from 5.25" Floppy
Reactions: slomacuser
slomacuser
143
Hm, you can copy files from the disk to hd and back? I have sys 6.0.5, you have 6.0.8? I should try that
RetroTheory
90
161
Yes, but only with PC formatted disks, not formatted with Dos Mounter. If I format the disk in a real PC or SoftPC I can copy files , but if I ms-dos format a disk with DOS Mounter it just hangs when I copy a file.
RetroTheory
90
161
Did a little disassembly on the Apple 5.25" PC Drive and it turns out its a near standard Panasonic JU-455-5 360K floppy drive.
Pinout attached. Drive is set at DS0.
Booting SoftPC using a Gotek Floppy emulator connected to the PC Drive Card.
  • Apple PC 5.25 Drive pinout .pdf
