Building a NEC PC-H98 Video Cable: 26w3 Weirdness!
Pawlicker
The NEC PC-H98 (or HYPER98) is a long forgotten MS-DOS workstation from 1990 or so, and based on the unknown in the west (but big in Japan) PC-9801 architecture. Specifically it has two modes, one that allows it to run PC-9801 software (normal mode) and one that allows it to run high-resolution software for the PC-98XA, XL, RL, and A-Mate models (that featured an expansion card for high-res video). A good way of describing the H98 is it's somewhat like the IBM PS/2: it featured unique ports and a brand new expansion bus (NESA) alongside the original bus (in this case C-Bus).
Mine is a Model 80 (an 80486 based model), which features a 16mhz 486. I wanted to get this up and running however there was one problem. The video cable information is undocumented outside of obscure Japanese web pages, and even then there isn't much information on what connector this machine needs. This seems unusual, until you take a look at the motherboard and notice a bizarre connector: a mix of a mini Centronics connector and 3 "video" pins from 13w3, except they're smaller than 13w3 pins. This was done for the same reason the Power Mac x100 models featured a weird connector as well, as the keyboard/sound/power switch were passed through the monitor cable too.
The connector has many nicknames including 26w3, composite 29 pin (or 複合29ピン), and is notorious even in Japan for being hard to get. To quote one site via Google Translate on saying why to explicitly avoid the H98 series:
So far, it seems to be convenient for games, but the reason why I can not recommend it is that the analog RGB connector connected to the monitor is special (composite 29 pin) and a conversion cable ("PC-H98-K04", NANAO P4A "MD" -C67 "is famous) is not available. For the time being, you can buy the connection cable at Tansei Tsusho , so you can make your own conversion cable. By the way, please note that in high resolution mode, screen modes such as interlaced and non-interlaced are switched with the reserved pin.
With the lack of a video cable being the main issue preventing this from being a useful computer, I decided to build my own. At first I was planning on removing the motherboard and soldering pins to it, but after a friend of mine sent me a link to an obscure Japanese website, I found out everything you need to build a video cable for this thing. The first thing you need is the DX30AJ-26P-CP3(50) (from Digikey) connector. This is a Hirose DX series connector. The connector lacks the 3 coaxial styled pins, which go by part number MJ-P-1.5CV(P)(40) and can be found on Mouser. I ordered the connector and confirmed: it fit.
The next step was to wire this up. To get non interlaced high-res video and 30khz normal-res video, also bridge pins 10, 11, and 12 to ground (the shield works). For reference, the full pinout can be found here and the resolution jumpers here. Notice the position of the 3 coax pins, they are ordered RBG instead of RGB. There are two staggered rows, the top row is pins 1-13 and the bottom row is 14-26.
Pin DescriptionVGAPC-H98
Red1A1
Green2A3
Blue3A2
Red Gnd6A1 Shield
Green Gnd7A3 Shield
Blue Gnd8A2 Shield
H-Sync131
H-Sync Gnd102 (CONNECT TO VGA PIN 10 ALONG WITH 4!)
V-Sync143
V-Sync Gnd104 (CONNECT TO VGA PIN 10 ALONG WITH 2!)
The most important thing is to wire up VGA Pin 10 to H98 pins 2 and 4. This has to be done, otherwise the video will not be synced properly and you will get an out of range error or rolling display. The other problem was wiring up the RGB wires, I ended up gluing the wires into the connector and reusing a junk VGA cable as it presumably wants some weird coax setup but inserting in the wires so it touches the coax pins works fine. It's not something I'd recommend for long term use though.
The end result? A PC-H98 saved from the junk pile.
Reactions: Kai Robinson
Wow - i have to say i've never seen one of these in the wild - so many unique Japanese market only systems out there. That connector looks practically hellish though - why would they use that?! 😂
Pawlicker
Yeah, a lot of Japanese computers are in a void of obscurity in the West, and while the PC-9801 and 8801 platforms have gained popularity in the past decade (to the point of LGR buying an OG 8801, though unfortunately not an MKII or newer) there was a lot of bad info posted on Western websites a while back.
The H98 and high-resolution PC-98 models (XA/XL/RL/H98/A-Mates) are not exactly well loved within the PC-98 family and unfortunately are also a documentation black hole. Because there was no way to add in support to older models, nearly all game developers chose to write games for either the 9821 video hardware or the third party Window Accelerators (that use passthrough for video similar to the Voodoo cards) when they wanted 256 color or better graphics. Furthermore High-Resolution mode actually changes the memory map of the computer itself and this causes major issues as software has to be modified for it.
