Connect ADC monitor to HDMI source
fehervaria
166
North Germany
I love the compact Macs from the middle 80s, but my other love is the PowerMac Mirrored Drive Doors with Apple Cinema Displays.
These displays have ADC connectors used to connect to specific graphic cards with ADC connectors. The Apple (and other) solutions to connect these monitors to DVI connectors is to use an ADC-to-DVI adapter with the power supply and USB connectors.
But today we do not have DVI based graphic cards and these Apple ADC-to-DVI adapters are quiet expensive.
I thought if I would like to use my beloved ADC based Cinema Display monitors (I own 5 of them) then I have to build an HDMI to ADC adapter.
And here we go, today I can show you two variants, one is the boxed version - like any adapters, the other is the extension card shaped adapter. I use external power source (max 28V/5A).
fehervaria
166
North Germany
Looks great! Were you able to source the connectors or did you have to scavenge from dead machines?
No, all components are brand new. I did not need to reuse old components.
I am located in Germany in Europe, and the transport (to US or outside from EU) could cause a lot of time and probably not very cheap.
I do some resource and figure out how to do. I have no problem to create "kits" for DIY, also no problem to build few "ready to use out of the box" and post them to anybody who need...
I'll write back soon.
fehervaria
166
North Germany
Long time but finally this week all of the components has arrived.
So guys, let me know who need what.
Please PM me about your details.
Just curious where you found the ADC connectors, and what you're using for the 28v power source? :)
fehervaria
166
North Germany
:cool:
Surplus Sales of Nebraska search for (CPC) DV3R035N11
I use an PSU for LED lines 120W / 24V / 5A. It is possible to tune, and the max Voltage is 27,5 stable supply.
I set mine to 27V. I use my monitor more than a year, more than
8h a day Mo-Fr (this is my work computer's monitor)
The power connection design goal was to able to use the adapter with fanless, cheap(er) PSUs.
The Power Supply of the G4 PowerMac gives 28V to the ADC connector and these power (ampers too) need for the USB hub in the monitor.
I use the monitor with USB microfone (Marantz Pod Pack 1) and web cam connected to it (iMac 2009 iSight with pigtale USBed).
ScutBoy
338
Northfield, MN USA
If you can make kits of the box version (all the parts, I'll assemble) I'm in for at least two.
Depending on cost, if you assemble as well, I might go that route :)
Reactions: fehervaria
averagejef
This excellent! how does one acquire one of your boards? I've been reviewing a couple of other builds, one with standard DVI connector and one that adds a VGA, yours seems much more efficient. been looking for a way to use my old cinema display that doesn't break the bank.
519
Me too, I’d love to support this initiative with a ADC/HDMI kit purchase -very useful adapter to have in one’s toolbox I think.
bagelboy99
I just picked up one of these monitors foolishly assuming that someone would already have adapters for these. So far I have only found like two people who have made these and neither of them are selling the boards. If you aren't selling the boards anymore do you still have the files to have the board made?
fehervaria
166
North Germany
Hey, contact me with details what you need, how many you need. I have the DIY kit, or I can assemble for you. Let me know what you prefer.
Synceen
Hey ive been trying to get my monitor working with my macbook (M1P MBP 14"), ive tried both a hdmi->VGA adapter that worked with my windows PC and now a 1st party apple USB C->VGA adapter, ive had more success with the 1st party adapter. Ive installed AW EDID editor, better display and switchresX and havent been able to work, i tried the settings i used on my windows PC
1600x1200.
65hz.
progressive,
CVT reduced blanking,
pixel clock 141500? hz,
refresh rate 64.994hz,
horizontal vertical
timing total 1760 1237
timing display 1600 1200
timing front porch 48 3
timing sync width 32 4
timing polarity Positive negative
