BlueSCSI Toolbox
2,004
#4 Flashing
Click "Auto-Flash" and when it's rapidly flashing it will update the firmware. Rapid flashing is the bootloader waiting to see if you will be flashing for ~2 seconds. Any doc updates are welcome in the wiki.
Eric, using Auto-Flash caused my BlueSCSIv1 to become non-functional.
I will send you a PM with a video and other details.
1,974
Updated to 1.0.2 - Few bug fixes.
Notable new feature that required no code changes is the SD Transfer app now works in the Snow emulator's bleeding edge build! I actually prepared the 1.0.2 release inside of Snow.
Changes
1.0.2 - 2025-09-29
- Fix issue with 0 byte files
- Fix issue with logo not appearing on some systems
- Fix apps not quitting on shutdown or restart
- Fix handling file names exactly 32 chars long
1.0.1 - 2023-11.12
- Fix issue with only 13 files being listed in CD and Transfer.
1.0.0 - 2023-10-12
- Initial Release
Blinkz
Hello there.
I have a question quick regarding the 1.0.2 release. Is there any additional prerequisites needed? I have three Mac SE/30's running internal and external BlueSCSI's and I found that on the latest release that System 7.1 reports an Error Type of 1 or bus error when ran on 7.0.1. When I go back to using the 1.0.1 Toolbox I have no errors and the applications work properly. Debug shows that it sees files in the Shared folder and the app starts to run but then quickly throws the messages listed above.
Let me know if there is anything else I can do to troubleshoot further.
1,974
Odd there's an issue between 1.0.1 and 1.0.2 as the changes are pretty non-invasive. I'm working on a v1.1.0 now and will test it on my SE. I'll post a preview build here when ready if a few people want to try it when it's ready.
mmaseda
Trying to use the Bluescsi toolbox for the first time. I have a V2 external with the latest version of the firmware and toolbox and am running MacOS 7.1 on a Mac SE. I have a folder on root of the SD card called named shared where I have several files. When I launch the transfer app I get a ‘No compatable BlueSCSI’s found’ error. CD switcher app works fine. Any ideas what I might be doing wrong?
Manuel
1,974
Great! Thanks for the feedback. I'll add the 1.0.2 back to the page and take a closer look at why the beta is failing (thats why it's a beta!)
1,974
Mihaip and I got BlueSCSI Toolbox working in DingusPPC and now mihaip has it working in Infinite Mac as a way to get files to a machine running dingusppc in IM!
Playing around with adding BlueSCSI Toolbox protocol support to DingusPPC. Though somewhat roundabout, the end result is that you can transfer files in and out of more emulated machine types on Infinite Mac. As a bonus, it also makes the Macintosh Garden library integration work.
It works for the 6100 running 7.1.2 (https://infinitemac.org/1994/System 7.1.2?saved_hd=false&blue_scsi=true), and you can try to enable it for any other machine via the "Customize…" dialog.
Many thanks for @nulleric for @BlueSCSI in general and specifically for fixes to the SD Transfer app and my DingusPPC virtual device (code for the curious: https://github.com/mihaip/dingusppc/commit/6c002e81e58eb336b345bca27973726fd150c139).
Reactions: Byte Knight
