System sounds in Sys6
gfuller
Random question: Is there any way to play System sound files that work in System 7 in System 6? I've converted some AIFF files to System Sound-format files that work in System 7, but obviously I have no way to open it in System 6. Are there any sound applications compatible with System 6 that may be able to play these sounds?
I've been using SoundApp 68k to convert 8-bit AIFF files exported from Audacity to System Sound files, which open flawlessly (even longer files over 3 minutes long!) on my Classic and PowerBook 165 running System 7. However, I'd like to see if I can get them to work on my "SuperSE," which is a SE with a Mobius 030 accelerator. The accelerator will not run System 7 in my experience, so I'm stuck at System 6.0.5 on it. (Although I think some people have got the Mobius cards to work with System 7.0, not sure anything newer though.)
Any help would be greatly appreciated.
Volvo242GT
384
223
Currently Duvall, WA
Kind of a necropost, but the old SoundMaster control panel works for this. Another utility not mentioned is the SoundBuilder 2.0.1 application. Plays any SND resources (aka sfil Sound files). Can even play them backward, if desired.
