Powerbook 180 & Tunnel Vision
Neo117
Sorry for the long post, but I needed to explain what I had done in order for my questions to make any sense. Note this this is just a record of what I did for the purpose of explaining my questions at the end of the post.
I recently came into possession of a couple of Powerbooks and started working on refurbishing them. The Powerbook 180 had a tunnel vision problem with the lcd screen as can be seen in the picture below (condition at 41 minutes after startup):
I decided to try to fix the tunnel vision issue and read some articles on the internet about potential causes. I found two potential fixes so I decided to try them in order of difficulty. First, I tried placing the lcd in a closed container with desiccants for ten days to see if that had any impact on the lcd tunnel vision. The picture below shows the laptop and lcd in a dry box with a humidity of 15% where it remained for ten days:
Unfortunately, after those ten days, I saw no real change in the lcd as shown in the picture below (condition at 45 minutes after startup):
Next, I decided to try baking the lcd as I had heard that baking could possibly help with tunnel vision. I removed the lcd from the laptop. Note that the half of the metal tabs twist clock-wise and half twist counter-clock-wise for removal. Then I setup an old toaster oven that I had (I didn't want to use an oven that would ever again be used for food in the future as I didn't want to risk contaminating it.) Below is a picture of the toaster oven with tray and parchment paper:
I ran a test with the toaster oven without the lcd to see how stable the temperatures would be. The lowest temperature setting for the toaster oven was 200F. I used a wired digital grilling thermometer to measure temperatures during the test. When the oven was set to 200F, the temperatures varied from 185F to 197F sinusoidally over a ~10 minute period. In order to stabilize the temperatures somewhat and prevent localized hot spots on the lcd, I placed the lcd on a sheet of parchment paper on a tray, then I placed another sheet of parchment paper on top of the lcd (neither sheet of paper touching the lcd screen.) By placing the paper on top and below the lcd, it created a pocket of air between the sheets where the temperature was stabilized to roughly 191F +/- 3F with a ten minute period. Below is a picture of the lcd and parchment paper in the tray:
Note that weights were necessary to keep the top sheet from being blown around during oven operation. I ran the oven for 5 hours with this setup (lcd experiencing 191F +/- 3F with a ~10 minute period.) The oven wasn't designed to operate for this length of time even at the lowest temperature so the exterior got hot, and I burnt my finger. After that, I allowed the oven and lcd to cool to room temperature naturally with the oven off and power unplugged.
After the lcd and oven reached room temperature, I reinstalled the lcd in the laptop so I could see if there was any improvement. Note that as I mentioned before that half of the tabs twist clock-wise and half twist counter-clock-wise so there wasn't much / any slop in the positioning of the lcd during installation. Once everything was reconnected, I turned on the laptop and discovered that there was significant improvement. Below is a picture of the laptop lcd after 42 minutes of operation:
Oddly, the lcd continued to improve over the approximately 3 to 4 days after baking despite just siting in the laptop not being used. In the end, this is what the laptop lcd looked like after those 3 to 4 days (note that the interference pattern is not visible to the eye - not sure why the camera shows that):
Note that this picture is after an hour of operation.
Finally, here are my questions for others that have done a similar repair on their 180 lcds:
1. Do you think that the ten days in the dry box improved the effectiveness of the oven baking? Moisture removal, etc?
2. Or was the problem actually that the adhesive between layers needed to be reflowed, and the time in the dry box did nothing at all?
3. Why did the lcd continue to improve over the 3 to 4 days after removal from the oven?
4. After the baking of the lcd, I have noticed a faint ghosting of windows that have been displayed for 40 to 60 minutes on a dark background. Is this due to the baking of the lcd or is this just the nature of some of the early active matrix displays? Barely noticeable in person to be honest and disappears fairly quickly. See the picture below for an example of a ghosted window after being displayed for ~60 minutes on a dark background:
5. Is this typical behavior of an lcd with tunnel vision or is this unique to my Powerbook 180 (sample size of one after all)?
6. Is the problem really moisture or the need to reflow the adhesive between layers?
Before I work on the next Powerbook (which is in awesome shape save the lcd), I want to make sure that I'm not doing something stupid and damaging the lcd beyond repair in the long term. Any guidance or recommendations would be greatly appreciated.
Reactions: Kai Robinson
2,044
Sadly, I don't own any of those models, and because of that, I have no answers to your important questions.
My concern would be that if HUMIDITY was the root problem, the tunnel vision would come back over time because you wouldn't leave it in a sealed container with desiccants all the time.
I'm also curious if ALL those PB180 models are affected by tunnel vision, and if not, why would that be? I guess we could say some people live in drier areas than others, but it would be nice to compile data about the people who have the problem and where they live, and how long they've had the machine.
I'd also love to see a video of the window "ghosting" you mention.
2,044
You seem to be talking about this very faint ghost window...
How long before it vanishes completely, or does it never vanish until power is cycled?
Neo117
If you power cycle it, then it vanishes instantly. If you don't power cycle it then it takes about 6-10 minutes to disappear. It is a little difficult to get an exact time because it is so faint as it disappears. Also, if you move another window across the area containing the ghost image, it is gone, and you can't see it anymore. It really doesn't impact usage and you have to really look for it to see it, so I may be asking too much for perfection given the age of the computer.
However, I think it is tied to the tunnel vision and not the baking of the lcd. I was able to look at a friend's powerbook 180 that is in better condition than this one but has a slight issue with the lcd. See the pictures below for the 2nd powerbook 180's lcd after 30min:
This is as bad as the lcd gets on this 2nd powerbook 180, and there has been no baking or desiccant treatments on it (or any refurbishment for that matter.) One thing that I noticed on this one is that you do see the faint ghosting on the very right side of the display if you leave a window up for a long time, but not on the left side of the display. As a result, I'm thinking that the ghosting may be related to the tunnel vision, but it isn't impacted by the baking of the lcd. I tried to get a picture of the ghosting effect on this one, but I couldn't get the camera to pick it up as it is extremely faint.
2,044
I recently did a video about the ZigZagJoe LCD Color Kit for the SE/30, which is a fantastic product. It makes me quite sad there is no similar solution for the PowerBooks. That old tech degrades, and while I'm shocked at how well your bake worked, the fact is the tech hasn't de-aged as a result of the baking. It will probably at some point go back to tunnel vision. It's kind of like baking the graphics card in 2009 era iMac's. It works a few times, and then the card dies, and you must seek other options. But when it comes to PowerBooks, there are no "other options" it would seem, in terms of a modern LCD replacement.
  • Sad
Reactions: haydonbeagley
Neo117
I have similar concerns about the LCD going back to tunnel vision at some point. That was one of the reasons why the ghosting concerns me even though it is very hard to see in person. I bought a bundle of four PowerBooks with the hope of being able to make one functional laptop from all the parts which I feel that I have been able to do. I now have the one functional PowerBook 180 laptop with the baked LCD and a BlueSCSI V2 that is working really well at the moment, but I don't know for how long. The other three PowerBooks were another 180 (fully functional electronics boards but the casing is in bad shape), a 170 (parts machine as previous owner tried to "fix" it but didn't know what they were doing,) and a 145B with almost all standoffs broken and plastic issues, etc.
For my next project, I'm going to see if I can design a micro-tower case that I can use with the electronics from the other 180 and see if I can set it up with an external monitor and keyboard/mouse. I'll have to see if this is possible, but it will give me a chance to experiment with my 3D printer and scanner. Probably a crazy idea but it will be fun to try and I already have parts on hand for the build.
3lectr1c
670
339
the United States
www.macdat.net
I have a PB180 with an essentially flawless display (if you look extremely closely after an hour and a half of running, you can see the faintest of faint darkening in the left corners, faint enough that it's impossible to see on camera). I'll see if it ghosts at all tomorrow. I'm fairly certain it's a normal thing for this type of display though, I believe that Mac OS actually has a warning about this built-in for the Macintosh Portable. I forget how to trigger it.
2,044
I have a 5126 Backlit Portable, and there are some very minor areas of darkness, but nothing on order of what this thread is showing. I also am aware there is no modern replacement for the LCDs used on the Portable, but is the same true of PowerBooks? They are all custom made panels?
Paolo B
307
186
Switzerland
Very interesting, thanks for sharing: it’s another confirmation that baking works better than desiccating.
I have a 170 which initially had some very visible tunneling. I store it in a lightly vacuumed bag with some desiccating pouches.
Progressively, over the time (mind: months), the tunnel effect has significantly improved, but not to the (almost perfect) extent you have obtained.
Or, more precisely, now when I start the PB the screen is perfect, but after some 30 mins or so the tunnel effect becomes visible around the corners.
So, my guess is that it’s a mix of humidity and glueing layers. Likely, the glueing layers are faulting allowing some humidity to seep in.
Baking may address both issues: extracting the humidity and somehow “reflowing” the layers (thermo plastic glue?).
Neo117
I'm wondering if the ten day treatment with desiccates did something that made the baking more effective. Not sure how to check that, but it is possible that it did something that helped even if it wasn't obvious. Maybe I should have done the desiccate treatment for longer than ten days.
BTW - here is a one month update picture of the display after baking the lcd on June 10th (exposed to 50-60% humidity in home office over the past month):
I'm not seeing any obvious changes, and I am still seeing the very slight ghosting after a window has been open for a long time. So no real change there as far as I can tell, but it is so slight that it doesn't impact usage. However, I do have sleep mode & dimming turned off so I'm going to turn those on and see if there is any change in ghosting over time.
haydonbeagley
31
38
United Kingdom
I've recently been given a PowerBook 180 with the B/W screen and my friend did the oven trick to fix its tunnel vision.
Sadly, it seems that if its been on for around half an hour the corners do seem to start getting darker.
Would it be worth attempting to put it through the oven again? Or just use it and swap in a alternative panel if it gets too bad?
Luckily do have a parts unit PowerBook 160 which does have a screen/mostly intact chassis.
croissantking
112
52
Yes, if it’s still darkening then it needs more baking time. Hitting the right temps is critical here. How long was it in for and at what temp?
Neo117
I wanted to give an update on the screen of the laptop that I baked above. Below is a picture of the laptop 6 months after the baking procedure described above after being on for three hours:
So far so good, it is going on 7 months now and the screen still looks pretty good. From what I've been able to determine, there seems to be a narrow window of temperatures where the baking works. Too cold and it doesn't completely fix it. Too hot and you damage the lcd. I'm going to try the process on another 180 sometime this spring without doing the step with the desiccant to see if that matters.
Also, the hard drive on my 180 failed so I replaced it with a BlueSCSI and reinstalled the OS. After including the Powerbook options in the install, I no longer see the after images that I was seeing previously when the laptop had been on for a long time. The options dim the screen long before any after images form, and, if I turn off the settings, I get the following screen:
It mentions a 24 hour window but it dims the backlight long before an hour and prevents the after images. So I suspect the reason that I was seeing the after images before was due to the OS not having the PowerBook options installed.
I will update the thread after I attempt the backing on the 2nd 180.
2,044
Wow. That LCD looks perfect from what I see in those two photos, with no unusual lines on the screen, no darkness at all that I can see, and no darkness in the upper right hand corner either.
In one of your earlier photos, you photographed a screen that had a little bit of curved darkness in the upper right corner. But your photos today show an absolute immaculate screen.
That says a lot about baking it at the right temperature!
Neo117
The screen with the little bit of curved darkness on the upper right corner is a different laptop. It belongs to my friend, and he has been pestering me to do the same baking on it in order to fix it. However, as little tunnel vision as it shows, I'm reluctant to take a chance with it and have refused so far.
The 180 with the baked lcd has remained completely clear for the last 6-7 months. So far so good with it anyway.
With regards temperatures, I have a coworker with a 170 that had tunnel vision. He baked it (without my help) about ~5-10 degrees lower than the temperature that I used. It greatly improved the tunnel vision but didn't completely eliminate it. Later, he baked it a 2nd time about ~10 degrees higher than the temperature that I used (using oven to set temperature - no digital thermocouple so no idea how accurate.) This time the tunnel vision was eliminated, but he ended up with some permanent black spots on the lcd. It makes me think that you really want to avoid exceeding (or even approaching) 212F for a long time.
The temperature controls on most ovens are not well calibrated so I would recommend using a digital temperature readout with a thermocouple and doing a dry run first without the lcd to be sure that everything is going to work as expected. Also, using parchment paper above and below the lcd (not touching the screen - air gap) seems to even out oscillations in temperatures that the lcd experiences and prevents hot spots from forming. I think my coworker had hot spots that exceeded 212F and that caused the permanent dark spots but that is only a theory.
