2UBG3: Beige G3 2U-Rackmount Build Obsession Revived!
411
Retrieving a 9 year old project from the pile-o-procrastion on the top shelf of the rack doesn't constitute the necro nonsense
Resurgence in obsessive/compulsive leanings here could be mania inducing, gotta watch that. This was brought on by tangential happenings in this year's Marchintosh project.
Old pics, I've got a far better 3 Card Riser than I had at the time. 1U PSU will be mounted sideways behind the logic board.
This one's from when I had it set up in a nook of the HackHutch.
Just pulled the trigger on the best 2U case I've ever run across at a reasonable price!
2U Server Chassis -Rosewill - $80
Of course it'll be torn apart and mounted backwards, pulling air thru the full length filters of the 2U Netra T2000 bezel that arrived today. Gotta get that 1U power supply to mount sideways for airflow overtop. Case arrives in three days . . .
2UBG3 case will slide in atop the 4U PEx/Netrat 1125 sans mounting ears. 6U of bridge machine goodness . . . at some point . . .
How many watts were the DT & MiniTower power supplies? Haven't got either handy ATM.
Reactions: eric
411
Made some progress on layout, trimmed plexi plate to fit atop the bottom cover plate of the 4U Netrat 1125 for visualization until the 2U Case arrives. It's fans will be at the back, pulling air in from the filtered 2U Netra T2000 front panel.
Board is set back from the front for cable management and 5.25" multifunction bay that houses laptop DVD. Cable races on left and right sides. Top will be hinged plexi for access to both sides. DVD and PSU are standins for fitment tests.
500w 1U PSU on the way, that's probably enough power.
It'll all fit, waiting time for parts now.
411
Thanks much! Visual thinking noggin' works in 3D. love bar puzzles! I can use all the encouragement/suggestion posts I can get in my topics.
If you like this puzzle, take a look at the old MLA thread for more pics of the minimum footprint 3U version. Had it working nicely with the stock G3 PSU PSU next to it, but lost immediate interest so onto the pile-o-procrastination on the Rack it went.
What's exciting about it now that it has the earlier(?) version of the Whisper Card @croissantking has updated with USB along with G3AIO Video Connector implemented. If anyone is interested in that G3 USB project, it's easy to tell the difference as the speaker/mic jacks are mounted much higher on the card than the later card in my pics here. ;)
This was the first implementation of the trap door concept. It's only 9" deep and a tad less than 11.75" wide, only room for a 3.5" bay.
Going full rackmount footprint with bit of Plexiglas origami, lopping 1U off the top splays things out nicely:
- moves PSU to somewhere sideways at the rear of the case
- makes room for floor mounted HDD just like the desktop donor
- moves personality card to right, mounted on the trap door via cable based PCI risers
- frees up cubic on the left for 5.25" multi-function bay
- movie sound card to the right
- provides cubic on the right to service PCI bay (will drill 3 holes on that side of the case for screwdriver access)
- large desktop grommet under multi-function bay will run cables to the outside world
- allows unplugging cables to slide unit off its 4U Sun Server shelf for service
Beautiful 2U Sun Server faceplate has:
- - hinges
- - clips
- - nice green rubber finger holds for flipping it down
- - power button with LED light pipe
- - recessed silver button for reset(?)
- - six more light pipes for LED playtime
Tracking# yesterday, but hasn't shipped yet for arrival within a week. I have plenty of time do my taxes before 2U case arrives. :rolleyes:
411
Taxes done in 1:08, so then spent three hours rearranging every shelf on the rack save the top one. Now I may need to raise a bit. That'll make room for the rackmount DVD player I put together. Took it out to make room, who knew? :rolleyes:
Got the rack for $15 cash from one of the workers at my recycler when the owner was out to lunch! But it only had two heavy duty steel shelves. Made a few shelves out of 18 gauge galvanized, man I miss my box and pan brake. Three major projects and the Win98se Missile Command launcher. Can pull the two servers off the heavy duty shelf whenever the fancy strikes . . . or new parts come in.
Fourth project would be the drawer carcass/shelf on the rack of procrastination for a quarter century now. :rolleyes:
Found the 5.25" bay multi-function module. Gotta put it in "upside down" for access because everything is set back in the case. 3.5" bay. Couldn't decide, so will likely have Superdrive FDD and Zip drive from laptops as well as optical. That should cover all the bridge machine requirements for my hoard. I've got a drawer full of USB port I/O thingamajigs, this one is shallow enough that it's out of the way of the hinged cable riser setup.
Tips-n-tricks time: If you ever see one of these pro-grade inspection sticker scrapers, snag it!
Had to get the thick foam padding for the PSU off the Netrat tid to have as a support shelf for the G3 build, Need to use a bit of turps on the goop when I open it up again.
Nothing I've ordered has shipped yet. :cautious:
411
Nope, stuff stinks to high heaven. Sign shop always smelled of turps, doesn't bother me at all. Apprenticed back in the hand lettering day, before vinyl cutting. It scraped clean, not hardly sticky, just bothersome residue.
411
Well, no plan of battle survives contact with the enemy . . . so it goes . . .
I LOVE this case, all machine screws, no rivets or spot welds connecting anything! But it does come up short of the acreage across which I'd splayed the components out in the pic above. Bobtailed butt sitting atop the bottom cover of the much deeper 4U Netrat here:
So after an afternoon of Inverse Jenga playtime, I was ALMOST able to cram everything in that I'd had in the pic above. Looks like I'll be losing the 3.5" HDD, but have room for at least a pair of the 2.5" variety . . . you can't always get what you want . . .
It all boils down to the dimensions of the PSU heading my way. Might work, might have to find another one that does? I have to put the PSU of either available width into the "Upper U" so it overlaps the floppy connector, but falls short of the PSU's cache extension wing. Depth has to be the shorter 190mm variety, but either 81.5mm or 100mm width units will do.
Pulling the removable media bay almost fully forward provides for drive & power cable clearance. It'll make media handling much more convenient.
That's three different setbacks already, maybe a couple more setback levels coming up!
Left side fan pulls air almost directly across the heat sink! They're three pin interface, but I'll probably just run that one at 5v, the others at 3.3v and call it done? No need to muck about with the back cover! It's all PSU hole, short PCI slot, ATX bung hole or grating!
Was hoping to keep the plexi base under the logic board, but pretty sure I'll need the height.
25+ friggin' standoffs drilled out! :rolleyes:
411
Found three sticks of 64MB EDO MEMORY RAM ECC UNBUFF 60NS DIMM 168-pin 3.3v in the HackHutch with the speaker and such. I think I got it to max out this machine or did I buy it for something else maybe? Anybody know offhand?
I've got a couple of stripped out towers with double the memory ceiling. Was planning to grab the best board of the ten or so G3s I picked up to keep out of recycling, but should I switch to a Tower Board in any case? Only have the two of those available.
Would 300w be suitable for this thing? Dunno what's in the towers?
Apevia ITX-AP300W 300W Flex ATX Power Supply
