Dell System 310/325
RetroViator
166
retroviator.com
Righting a Wrong​
My company was cleaning out an old telecom closet when they decided to get rid of the "door stop" they had been using to prop open the door when working in the tight space. It was a Dell System 310, or so it seemed. The IT guys knew of my interest in old computers, and I was delighted when one day I walked into my office and found it sitting on my desk.
My excitement held until I got it home and discovered that its motherboard had been replaced. The original 1989 Dell motherboard with its 386DX was gone, replaced by an Amptron PM-8600 with a 233MHz AMD K6. I should have known something was up when I saw a 36x CD-ROM had replaced the original 5.25 floppy.
I thought about making it into a sleeper system, but instead I set out to find the original motherboard. A year later, I was blessed with a fruitful eBay alert, and the original board was mine.
Now, I'm going to restore the computer to its proper configuration. The original motherboard looks good, though with plenty of tantalum caps waiting to pop. Its RAM is missing, but it should use standard 30-pin SIMMs — a real plus, considering many systems of this era used custom memory cards (it also has a custom memory expansion connector). One wrinkle is that the system lacks an onboard keyboard jack. The jack is supposed to be mounted in the case above the motherboard and connected using a 4-pin header. I'll have to figure that out.
This will be my first 386DX system. I longed for a 386DX system back in the day, but I could only swing an SX. And thus far, all the 386s in my collection are of the SX variety.
I've been looking forward to working on this one for a while.
RetroViator
166
retroviator.com
I did more research on the motherboard, and realized that I won't be restoring the System 310 to its original condition because I have the motherboard for its big sibling, the Dell System 325. The 310 is a 20MHz 386DX and the 325 runs at 25MHz. When released, the System 325 was Dell's flagship computer.
Luckily, I was able to find the original installation and troubleshooting manual on Archive.org. After uploading a high-resolution photo and other information to The Retro Web Discord, I sat down and studied the motherboard. It looks good, but when checking the AT power supply connector, I see the following:
JPS1 ConnectorPower SignalOhms to Ground
Pin 1Ground0 Ω
Pin 2Ground0 Ω
Pin 3-5 V+ MΩ
Pin 4+5 V+ MΩ
Pin 5+5 V0 Ω
Pin 6+5 V+ MΩ
JPS2 ConnectorPower SignalOhms to Ground
Pin 1Power Good0 Ω
Pin 2+5 V0 Ω
Pin 3+12 V0 Ω
Pin 4-12 V+ MΩ
Pin 5Ground0 Ω
Pin 6Ground0 Ω
So, I have shorts on two of the +5V lines and the +12V line. I count more than 50 dipped tantalum caps and even more axial ceramic caps. Any cap I check is a dead short back to the power connector, so I don't have a good place to start. I tried removing a few of the caps nearest the power connector, and I found the ground plane makes it very challenging to get caps off the board, but when I lifted the positive leg, nothing changed.
Unless someone has a better idea, I may start with removing all the socketed chips, and see if that makes a difference.
RetroViator
166
retroviator.com
I found the culprit, and I was very lucky. I started pulling ICs, and I started with the 386DX, the Cyrix FastMath co-processor, and the Intel 82385 cache controller. I then tested for shorts before pulling more, and the resistance was up to 400 ohms on the previously shorted rails. So I reinstalled the ICs one at a time, and found that the dead short returned when I inserted the 82385. (With all the other ICs installed, the resistance was around 370 ohms.)
I tested the board by injecting current from my bench power supply on each of the previously shorted rails. Nothing popped or got hot at either 500ma or 1 amp.
I've now ordered a replacement 82385 from eBay, and I'm starting to think this board might boot.
Reactions: Kai Robinson
RetroViator
166
retroviator.com
I opened the power supply and found it to be dusty and in otherwise good shape. I cleaned everything, oiled the fan, and tested the PSU. It ran just fine.
So I decided to plug it into the motherboard and see what happened--and nothing happened. The power protection kicked in. That got me thinking about something that had been nagging me. While removing the cache controller cleared the short to ground, how could removing the cache controller clear a short on the +12V line? And why do I have the same resistance between the +5V and +12V rails? Is it possible to have a short between +5V and +12V? What could bridge those power rails?
So, I checked pin 3 on JPS2 and confirmed its a dead short to pin 1 and 2 on JPS2 and pin 5 on JPS1. That is not right!
Now I'm really glad that when I injected current from my bench power supply earlier, I only tested the +5V rails. I was going to throw +12V at pin 3, but I think I only used +5V--at least I think I did. 😨
I'm open to suggestions on where to start hunting for components or ICs that could bridge the +5V and +12V lines.
RetroViator
166
retroviator.com
Wait a minute... I have been thinking of the AT power supply connector backwards. I've been going at this all wrong. When I plugged in the PSU, I should have noticed my mistake, but I did realized the problem when I started checking resistance between the power supply connector pins and the ISA bus connectors. The connections weren't lining up.
It really lays out as follows:
JPS1 Connector (P4)Power SignalOhms to Ground
Pin 1Power GoodOpen
Pin 2+5 V363 Ω
Pin 3+12 V0 Ω
Pin 4-12 V14 MΩ
Pin 5GroundΩ
Pin 6GroundΩ
JPS2 Connector (P5)Power SignalOhms to Ground
Pin 1GroundΩ
Pin 2GroundΩ
Pin 3-5 V61 MΩ
Pin 4+5 V363 Ω
Pin 5+5 V363 Ω
Pin 6+5 V363 Ω
Pin 1 is toward the outside of the board not the inside. I can be really dense sometimes. 🥴
So, there is a short on +12V, and a short on the +5V when I insert the cache controller IC (not shown in the chart above).
457
Very cool stuff, gotta make an encouraging post, hate it when my projects never get them. Likes suck.
Best of luck with this great project, have at it and keep us updated.
I could only swing building an SX/25 system with FPU (SCSI card/HDD too) back in the day for graphics when CorelDraw and WIN 3.0 were released.
Finally got a nice 386DX/33 Tower when doing a development project! Didn't make any money, but very nice toys collected in the effort. :)
Reactions: RetroViator
RetroViator
166
retroviator.com
Thank you!
I have been using this as a project log, which may not be how some would like to see the forum used. I figure this information might help someone else if they get a similar machine or face similar problems.
I appreciate you reaching out and providing some encouragement! I'm a bit stuck at the moment, but I'll take a break and see what comes to me.
457
Not to worry, I've used every forum that's been around for my project logs for all manner of stuff! I always ask for help and many times members will pitch in to do the stuff that's way above my pay grade. Besides, this place needs all the real interaction it can get in the fora.;)
RetroViator
166
retroviator.com
I picked this project up again, and I've had some success, but not enough.
I was able to find the cause of the short on the +12V rail. By injecting 1V at 2Amps into the +12V power pin, and using my thermal camera, I saw a 10uF ceramic cap was getting hot near the PSU connector. After replacing it, I plugged in the PSU and it fired up... for about 30 seconds. Then, it shut itself down. Now I had a short on the -12V rail. This time, instead of injecting power, I looked at the -12V ceramic next to the one I had just replaced, and yep, it was shorted. So I replaced it too.
The motherboard now powers up, but it's lifeless. I put in 4x1MB 30-pin SIMMs and a VGA card, and nothing happened. So, I pulled out the thermal camera again and found that the CPU was stone cold. A good number of other chips are getting warm, with a nearby PAL running the hottest at around 72-degrees C (most others are around 50-degree C).
The CPU may not be running because I don't have the Intel 82385 cache controller installed. When installed, there is a short on the +5V rail. So I bought a new one. However, the same thing happens when I put in the new IC. This has me wondering if the IC was in the correct orientation when I got it. Considering the only photo of this board is the one that I uploaded to The Retro Web, I don't have a way to verify other than checking the pins on the socket--and they aren't matching the datasheet for the 82385. I'll have to noodle on this, but it has me wondering if the CPU is also inserted with the correct orientation. It probably is, but I would like to know for sure. Unfortunately, this motherboard has no visual indication for pin 1, except for the math co-processor.
RetroViator
166
retroviator.com
Thanks to some help on the Vogons forum, I figured out the problem with my CPU and cache controller.
The orientation was correct, but the chips were swapped! The CPU goes in U386, next to the FPU, and the cache controller goes in U385. Now that I know that, I can see it identifies the chips on the PCB (U386 is the 386 CPU, U385 is the 82385 cache controller).
So, someone was messing with the ICs on this board before I got it and put them back in the wrong location.
Next, when I powered it up, I saw some heat being generated by the CPU and a little by the cache controller. However, while most of the board was heating up, I did not hear any beeps or see any video. I had a replacement CPU so I put it in, along with pulling the BIOS chips and using Deoxit on the sockets. Finally, I plugged in a POST analyzer card. The power rails were good, and I could see it clear reset. The frame and clock lights were staying on, and the seven segment display stopped at 04 03. The Retro Web says this is an AMI BIOS, so I started thinking about the RAM.
I had installed 4x1MB 30-pin SIMMs. I pulled them out and put in some parity RAM and the POST codes started flying by. I heard two beeps, but still no display. After swapping more RAM and wringing my hands, I started checking my equipment. Swapping VGA cards didn't make a difference, but then I checked the display cable and found the connector was not fully seated on the back of the monitor. Once properly plugged in, I could see the system booting!
Now I need to make a keyboard connector. The system does not have an on board keyboard connection. Instead there is a four-pin connector that runs to an off-board AT connector, now lost. So I'll need to make one. Then I can enter setup and finally put this computer through some tests.
RetroViator
166
retroviator.com
Wiring up a DIN connection is never fun, but it happened. I was able to determine which pin on the motherboard was connected to vcc and which went to ground. After that, it was a guess which was the clock and which was data. I messed up due to a bad diagram, but once I was looking at the correct pinout, my first guess was correct.
With a functioning keyboard, I could get into the system BIOS. It is bare bones, but everything looked okay. Next I'll put it back in its case and start working on getting a disk to load DOS.
