Outbound Laptop Capacitor List & Repair Log
Elemenoh
460
448
Bay Area
I recently got an Outbound Laptop with its original 12V AC power supply. I was able to get it to power up once, but the next day I could not get it to power up again. First stop is caps. I'll share a cap list and repair journal here. Hopefully it'll be an easy one.
There is a lot more info and helpful resources at this 68kmla post.
MLB Capacitor List
QuantityLocation(s)TypeCapacitance (uF)Voltage RatingSize (D ✕ H mm)Lead Spacing (mm)
5C1 & 4 others unmarked on back sideThrough Hole (Axial)220168 ✕ 16N/A
2C10, C50Through Hole220106.5 ✕ 122.5
2C8, C33 (C33 Positive is bodged to a nearby cap pack)Through Hole100256.5 ✕ 122.5
2C51, C63Through Hole10355 ✕ 112.5
1C62Through Hole47358 ✕ 123.5
Elemenoh
460
448
Bay Area
I recapped the MLB and discovered a few things along the way.
1. 4 of the 5 axial caps are not accessible from one side. Their joints are below 6 ICs and a connector. I ended up cutting them out, heating the remaining leads and pulling them out, then clearing out remaining solder with braid. I soldered the replacements from the top side.
2. After I replaced the caps I had the same no-boot symptom. I checked with @zigzagjoe on discord who let me know you have to have a working battery in the keyboard to get the unit to boot. I guess when I got it to boot the other day the battery from 1990 let out its last breath. He said you can substitute the very uncommon CR12600SE battery with 2x more typcial N-types. I connected my bench power supply to the battery terminals and sure enough it then powered on with the keyboard arrow keys. But it just displayed a black screen with yellow lines. I suspect I didn't connect the display or something else properly but we will see.
3. Zigzagjoe also mentioned that the system expects the main battery to be installed and the manual recommends not running without a battery installed. I haven't been able to find a replacement SLA battery online yet but will keep looking.
So right now the machine isn't working, but when I next get a chance to work on it, I'll check all the connections first.
Also, I measured the removed caps to see which were out-of-spec. Most were fine enough but a couple of the 220uF's were very bad.
220uF / 16V:
207uF .46 d
3.2pF .55 d
2.1pF .14 d
200uF .9d
212uf .4d
47uF / 35V:
41uF .3d
100uF / 25V:
93uF .2d
93uF .25 d
220uF / 10V:
186uF .7 d
188uF .7 d
10uF / 35V:
9.4uF .1d
9.5uF .1d
ScutBoy
352
Northfield, MN USA
My distant memory of my Outbound is that the main battery is a fairly (once upon a time) common VHS camera battery.
I did not have the A/C adapter for mine, but the internet told me that the adapter for a contemporary Roomba was an exact voltage/amperage/plug match. I did trim back a bit of the plastic on the machine side plug so it would fully seat.
I'd love to see a picture of the outbound motherboard in hi res, be interested to know how they duplicated the apple asic's!
trag
406
193
Interesting that there is a 32K X 8 static RAM on board. M5M5256bkp
Does the Plus/SE have one of those? I never noticed before. Or is that doing PRAM duty that a custom clock/PRAM chip would do in the Plus/SE?
SuperSVGA
80
51
It's for video RAM, some global variables, and stack during early boot/patching.
Reactions: trag
Elemenoh
460
448
Bay Area
Still just getting horizontal lines on the screen. They're usually regularly spaced and thin, but occasionally chunky and random.
Things I tried doing that didn't change the symptom:
- Separated back panel from system
- Removed ROM
- Cleaned ROM and RAM incl. sockets with contact cleaner
- Removed hard drive connector
- Wiggled display connector
- Removed a cut cap leg that was attached to the speaker magnet
Next I'm going to tear back down to the MLB and check for shorts and opens around the caps I replaced.
trag
406
193
It's been about 30 years since I had eight of these to work on/with, but I think you may need to replace the flat flex cable to the display. I don't know if t hey still do, but Digikey used to sell one with the correct number of conductors, the right pitch and the needed ends.
Elemenoh
460
448
Bay Area
Thanks. That makes sense intuitively. It was a bear to get out and might have gotten damaged. I’ll beep it out.
trag
406
193
Do you know what itd be listed as other than a flat flex?
Geeze, it's been a long time. Maybe FFC? I think when I was ordering a replacement they still mailed out a paper catalog, about the size of a phone book, not that anyone knows what that is anymore either. Sigh.
trag
406
193
I found the packaging from one I ordered back in 2005. Boy I'm a pack rat. I don't know if this old of a part number will help but it can't hurt.
It's Digikey. P/N: A9BAA-1708E-ND
Description: Flex Cable -- AFJ17A/AE17/AFH17T
