LCD Replacement for the Macintosh Portable
Froggy814
160
46
Squaw Valley, CA
Finally was able to export my code today! Hopefully it works. Unfortunantly I followed a schematic blindly and need to figure out how to supply 3v to the rp2350... The part I got isn't outputting anything! Hopefully I can just replace it with another of his 10 buddy's and see if it works then.
698
I have bummer news. I don't think a plug and play is possible for the Porrtable's LCD port. Because Androda moves the old connector over... As stated in the description here:https://androda.work/product/macintosh-backlit-portable-m5126-screen-flex-cable/
So I have to find a new route, sooooo, Building a card time! After measuring leads with my oscilloscope that I just bought. (Really excited about that!)
Ah, that's correct. I had to send in my old cut cable for him to re-use the connector. Would it be possible to remove the board connector and try to solder on a modern connector. Would likely require bodge wires and maybe some drilling.
Or, maybe for a less destructive option you could solder wires to the rear video port connector. I have the external adapter Androda made so there is a video signal being sent out on that port that could be used. His adapter uses a raspberry pi, not sure how different it is from your device in terms of processing the signal.
Reactions: Froggy814
Froggy814
160
46
Squaw Valley, CA
It's about the same device, but I found an another approach to take at the plug and not mangle anything. Not gonna share it until it shows up. I don't want it to be a whole mess of soldering and drilling or anything, more of a almost drop-in procedure!
Reactions: wottle
Froggy814
160
46
Squaw Valley, CA
I plugged my RP2350 board into my computer, I am supplying external 3v3 power because what I put on didn't work. (Don't follow instructions blindly. Double check.) I but when I turn on the power, nothing happens. Zip, NADA, Zilch. No power pulled, not showing up on my laptop, even in device manager. No file explorer popping up when I hold the bootselect and then turn it on. I double checked the schematic, and that power is getting to where it needs to. I am even getting 1V out of the generator. I don't know what is wrong, if you can give me any pointers that would be appreciated.
P.S. It could be that the RP2350 is dead. I applyed some serious heat when I first put it on the board, but would it still generate 1V if it was dead? And how is it generating Voltage without drawing any amps, so confused 😵
Froggy814
160
46
Squaw Valley, CA
Not finished but, an update non the less. I think this is all that is "needed"! I don't need the LEDS but they will be the power indicators.
My old plan didn't work, but this one will! Right?
P.S. I am much more active on 68kMLA...
Froggy814
160
46
Squaw Valley, CA
I think finished routing most of the Traces, decided to add an expansion header as well, maybe for DEBUG purposes? It just connects to 4 of the GPIOS one of the Level shifted pins and 5v 3V3 and GND, should I add or change any of those? Also what do you think?
techknight
131
132
North Carolina
No, when you lay out an RP2350 or likewise design, you have to follow the layout guidelines exactly to a T, or your DC converter doesn't work/wont run. I saw discussion in a different discord where someone was struggling with this.
Froggy814
160
46
Squaw Valley, CA
You are soooo right... This is now something I will let the experts do, instead of soldering the pi together and designing that myself. Thanks for the info BTW
Froggy814
160
46
Squaw Valley, CA
I have! It's a little big because it is 4:3, so a 16:9 will fit better and look more original in the Portable. The original screen is 16:10 (or 8:5 whichever you know it as). I haven't really looked into LCD options though. Right now I need a working board that outputs video... Which I unfortunately don't have, yet...
Reactions: 360alaska
Froggy814
160
46
Squaw Valley, CA
Hey @360alaska! This is the LCD that I was thinking would be the best fit without 3d Printing an entirely new bezel.
