Snow EMU - Emulator for 680x0-based Macintosh computers
PL212
70
45
I am, I think:
But the vendor is still SNOW:
2,339
What system are you running?
What CD Image are you using?
What CD-ROM extension version are you using?
PL212
70
45
My host machine is actually Golden Gate, as of today.
The emulated machine is a IIcx with a Toby cared running System 7.1, installed from the Apple Mac OS 7.1 MultiPack CD-ROM, which is the third download on that page.
For CD images, I've tried a few dozen ISOs and Bin/Cues, drawn from the Nautilus collection on the Garden. All of the ISOs validate in DiskJockey, at least. (The Apple 7.1 CD itself also fails to mount, for what it's worth.)
The CD-ROM extension is from the installer Apple included on that CD-ROM, version 4.0, which is available in this path:
System 7.1 CD-ROM/U.S./Administrator Tools/Disk Images/CD Setup Disk/CD-ROM Setup.image
I've also tried the 'hacked' version the driver on the Garden, which allegedly removes all vendor checks:
I also tried FWB CD-ROM Toolkit 1.0 and 2.0; the former fails silently and the latter declares the drive to be unsupported. (Wonder if it's the vendor string there as well?)
I did triple-check that Snow had local disk permissions -- it happily mounts .hda and floppy images from the same folder...
2,339
I dug into this with Snow's SCSI trace and the 4.0 driver.
Apple CD-ROM 4.0 (DRVR 32 ".AppleCD", from CD-ROM Setup.image on the 7.1 CD) checks two things when it probes a drive:
1. MODE SENSE page 0x30 has to come back with 'APPLE COMPUTER, INC '.
2. The 16-byte INQUIRY product field has to be one of exactly three strings: CD-ROM CDU-8001, CD-ROM CDU-8002, CD-ROM CDU-8003. They are at offsets 0x47FC, 0x480E and 0x4820 in the DRVR
Snow reports CD-ROM CDU-8004. That model only shows up in the later 5.x driver, whose table added 8004, 8005, CR-8004 and CDR-8004. So 4.0 rejects the drive.
I reproduced it in Snow on a IIcx with the real System 7.1 CD as the media:
- 7.0.1 + Apple CD-ROM 4.0, product CDU-8004: doesn't mount.
- 7.0.1 + Apple CD-ROM 4.0, product CDU-8003: mounts.
- 7.5.3 + Apple CD-ROM 5.3.1: mounts either way.
CDU-8003 is in both extensions - fixed here: https://github.com/twvd/snow/pull/371
Reactions: thecloud
PL212
70
45
Fantastic -- checked out from your PR and:
Thanks for both the fix and explaining how you researched it. I'd never played around with the Peripherals or Breakpoints windows before; I'm guessing you knew enough about SCSI to know what to monitor?
2,339
Partly - I saw it send an INQURY then stop so knew it could "see" the drive but rejected what the INQURY response was. Then I just looked in the extension for the common strings and noticed 8004 wasn't there, but the others were.
I've also contributed the BlueSCSI Toolbox to Snow so already familiar with the SCSI system there - it's such a treat to work on a modern emulator.
Looks like @twvd already merged it too so it'll be in the next release.
