Fascinated by some of the Snow White prototypes - So I made one
751
I saw this one, and thought it would really translate well to a modern design (LCD, Pi running OS 7 emulation, etc). I also had temporary access to the latest Claude frontier model. I couldn't figure out the name for this concept design - I found one reference in an Apple Design PDF that is could be named "Happy" after one of the dwarves, or possible part of a collection called ""Macintosh Studies.
AI disclaimer: I know this some people will be put off by my use of AI, but I got into computers because I was fascinated by what it could do. So for me, exploring the boundaries of new technology is why I got into computers. So if it's not for you, I understand. No need to announce it. I'm not encouraging anyone else to participate in this project or even to consume it. I suspect there needs to be a feature for us users to tag posts that are AI adjacent and an ability to filter those out for people who don't want it in their feed.
Onto the process. Having spent weeks (months) building a custom case for my Lisa Mini. I was curious while I was out of town, how close I could get making a model that would house an iPad LCD, LCD controller board, raspberry Pi, and some power hardware (a 12v USB-C input and a buck converter to power the Pi). I didn't have access to my home computer, so I just was using my phone and access to Claude Fable 5.2, temporarily included with the regular $20/mo paid plan. I also wanted to view the progress, so I asked the agent to provide animated visuals of the assembly of the device. I provided an initial prompt and an image of that I wanted the case to roughly look like. It created a device, and I provided some follow up clarifications, some corrections to work done, but I think it was all done in about 15 prompts. And it created a really nice, well thought out model that was actually optimized to be printed in pieces (without supports).
OK, so that looks really cool. But what about printing this thing - does it actually work when made physical?
Turns out, it did a really good job (excuse the color - I printed in filament I don't use often in case it didn't work). The Pi mounted properly, as did the USB-C trigger board I used. The fin assembly in the middle (which was one of the reasons I liked the design because it felt like a merging of Apple and NeXT) worked on the first print. The components went together and the slot for the SD card was in the proper spot.
Were there some issues? Yes. There were screws for connecting pieces that were inaccessible due to other parts being in the way. A side panel was secured on two sides, but not a third to give it a solid joint. Originally it made it way too thick. It would have made cable management and assembly much easier, but I had it narrow it to optimize for style. It noted the device could have a tendency to tip forward, so I had it put a weight slot on the back base piece that will allow me to slide a piece of steel in there to give the base some weight.
But, largely, it worked just fine on the first shot. I probably wasted 2-3 spools of retro platinum PLA on my Lisa Mini build. While I enjoyed the iterative process of making the Lisa Mini case, ultimately, when the output is costly in terms of 10s of hours of print time, and filament costs, it turns out these latest powerful models can really help get it right earlier in the process. Another nice thing about this process is I asked it to optimize for printing, including allowing it to be printed on a 250mm print bed (the most common full size 3d printer bed). My Lisa Mini unfortunately requires a large format printer. But this one can be printed by most people on their existing printer.
I'll be publishing all the files, along with my custom emulator setup that I used on the Lisa Mini, which allows you to run a variety of Apple (and Apple adjacent) emulators on the Pi.
robertseward
For the inaccessible screws, could you add counterbored access holes from the outside, or switch those joints to a snap-fit? That might also help with the side panel that lacked a third securing point.
751
I was able to adjust the two screws that were inaccessible by shifting them a bit, then doing a notch out of the blocking part. For the side piece, I simple added a small ledge to give it something to press up against. I think with the existing 3 screws, that will give it enough stability. I'm printing now in platinum, so hoping that those adjustments pan out!
PL212
71
46
Ambiguity over AI aside (which I share), this is a great idea. Lots of great stuff in Apple Design -- seem to recall someone else trying to build the Jonathan?
Wonder what year the 'Happy' was from -- logo and typeface seems to suggest Apple II-era?
Reactions: wottle
751
Yeah, another cool design that could take advantage of the dual HDMI output of the Raspberry Pi is this one:
Anyone know what these concept designs were made of? They look almost like concrete to me, but that seems excessive for a concept device. Some sort of lighter weight clay? Did they sculpt it, or cast it in a mould?
Did a pretty good job modeling this one, although I'm not sure if I'll construct this one. I only can order so many iPad LCDs!
I might need to have it do a better job modeling a silhouette iPad LCD display housing. I made one long ago, but it didn't have mounting screws on the back for the rear case, and it didn't have an internal space for the controller board. So it has a flat plate hot clued to the back, and the control board is hot glued to that, exposed to the world! Would love to redo this properly and get it printed in retro platinum. It's been my vintage display for a while because it's powered easily with my 12v USB-C adapter, it's light weight and it has VGA, HDMI, and RCA inputs. It was very similar to this, but with a built in display instead of a slot for an iPad.
751
OK, final version is printed and I think it turned out pretty nice. I added a spot for an old Apple logo from a damaged case:
Will be getting everything buttoned up and assembly instructions / BOM put together shortly. Currently I put in a Raspberry Pi 5 with a separate 12v power supply that runs the LCD and the Pi. The LCD is an iPad 3/4 screen which has a much higher resolution, but the Pi seems to struggle running emulators with the higher resolution, so I need to look into how I can improve the performance. I may replace the LCD with a 1024x768 iPad 1 LCD. Should be mostly drop in, but some changes needed for the 12v power to the LCD (vs 5v for the iPad 3/4 controller) and different mounting tab locations that could cause problems getting it to fit properly.
751
I made a fun little side-by side of the original concept with my printed version to compare. I think I got pretty close to the original.
Also, the Lisa mouse seemed a bit out of place with the concept Mac, so I decided to replicate the early Mac mouse to fit an M185 inside. It has some improvements to the original design. Mainly, the challenge of getting the button height just right. The solution was to make the button presser portion of the part an M3 screw that can be tightened or loosened to get just the right height above the PCB. It seems to be working well.
Now I'm just trying to figure out how best to print it. Eventually, I'll likely do the same that I did with the Lisa mouse and get the top parts (top shell and buttons) printed in resin. They are tricky and I really don't see a way to print the mouse top case without support marks and/or layer lines. Resin resolves both. Making a few tweaks and will post the files for others when I feel good about it.
