128K Analog Board & Logic Board Capacitor List
Elemenoh
431
418
Bay Area
I'm in the process of doing a full recap on a 128K Mac and was having a hard time finding a complete list. So I made my own. This is for the 120V version part number 630-0102. The physical sizes might be off by a part of a mm, but replacements will mostly be smaller anyway.
Notes​
  • If you need the 240V version, check out this post.
  • 33uf 25V is a bit cheaper than 16V, so I plan to replace all with 25V.
  • The typical C38 replacement (PME271M610MR30) was out of stock at Digikey in February 2022. I ended up ordering PME271M610MR04. I haven't been able to identify the difference yet. Hopefully it'll be fine.
@Mac84 FYI since you commented about this on my IG post.
Location(s)CapacitanceVoltageTemp RatingPackage~Diameter (mm)~Height (mm)~Lead Spacing
Analog BoardC13.9uF (replace with film type)250105ºRadial33x16.5277.5
C24,700uF1685ºRadial1837.58
C3, C30220uF16105ºRadial10.5186
C547uF1085ºAxial6.514N/A
C6; C1422uF5085ºAxial6.516N/A
C910uF16085ºRadial1016N/A
C1133uF2585ºAxial612N/A
C1333uF1685ºAxial6.513N/A
C24; C292,200uF10105ºRadial16317
C25; C26; C311,000uF16105ºRadial16257.5
C35; C36100uF20085ºRadial18337.5
C380.1uF X (Replace with X2)275110ºRadial23x6.51420.3
C39; C43470uF1085ºRadial10155
Logic BoardC5; C2033uF1685ºAxial512.5N/A
C224.7uF3585ºAxial512.5N/A
AndyDiags
94
168
Your list seem to be missing C14, as well as the two safety capacitors C33 & C37. One important number you're missing is the lead spacing,.
JDW did a great video on recapping this board a couple years ago. I highly recommend you watch it if you haven't.
He also provides a link to a Mouser cart in the description which has all the required parts listed.
Lastly, JDW also has this Google Docs Spreadsheet which has details on each part.
Reactions: wottle
Elemenoh
431
418
Bay Area
Good catch. I've added in C14. It's a 22uF 50V axial like C6. I did not include C33 or C37 (Ceramic disc caps) since I've never seen those fail and AFAIK are not common to replace prophylactically. I can add them in here as optional if others think it's a good idea.
Edit: @JDW are you recommending replacing the filter disc caps since they might fail short?
Would you mind adding this to the resources section, too? :)
Many Thanks, Kai
Mac84
311
445
New Jersey, USA
www.mac84.net
Excellent work! 🎉
I’m curious, is your Analog Board marked as “1983” or “1983-1984”. I have one of each so it would be interesting to note if there are any differences. Thanks again for your contributions!
Elemenoh
431
418
Bay Area
It says "1983-84"
Reactions: Mac84
Elemenoh
431
418
Bay Area
Just for completeness, I noted the OEMs for each capacitor on this specific board in case that's interesting to anyone. I've noted 'Nippon Chemi-con' as marked, but I think they're now known as United Chemi-con.
