Adding termination power to the PowerBook HDI-30 adapter
2,305
I've been doing a lot of development on my PowerBook 170 - which also has a new battery from @jcs - and was getting annoyed at having to power my DB25 externally. Using a DB25 for development is just easier as I can reflash and grab the SD card quickly.
Which got me wondering why does the HDI-30 adapter on the PowerBook not pass through TERM POWER?
I toned out the HDI-30 to DB25 and sure enough the term power pin was connected.
Next I took apart the laptop and toned out, and the pin exists disconnected on the board.
So.. I took some bodge wire and connected it from the internal SCSI term power to the 5v line on the existing SCSI connector:
Result is a working HDI-30 powering a BlueSCSI v2!
Should add a diode in there to protect the PowerBook later, but it's working great now.
If you give it a try let me know if how it went for you. Also be sure to superglue back all the broken standoffs when you take the motherboard out :)
