The NeXT cube that had been sitting in my basement "just worked" after I added a new battery, a BlueSCSI and unplugged the MO drive. I found [this list](https://github.com/rjbrown99/next/wiki/NeXTStep-Software-Ports) of software to add ssh, newer gcc etc, and worked through the list. Cool!
After that was done, I wanted to find the latest version of curl I could build with gcc 2.95.3. I figured out the right flags for curl 7.17 myself, but things started getting weird around version 7.20 (released in 2010!). I asked AI to help over ssh, and to make a long story short, one of the problems was that the configure script would fail consistently with
Is anyone interested to run this on their NeXT hardware to confirm? I'm running 3.3 with CISCUserPatch3 installed and ~30 year old capacitors.
subs.awk:2 invalid char '' in expression. Evidently the subs.awk file was corrupted, and Claude identified it as a bug with symlinks in the NeXT kernel. I asked it to write a test script to reproduce the bug.Is anyone interested to run this on their NeXT hardware to confirm? I'm running 3.3 with CISCUserPatch3 installed and ~30 year old capacitors.
Code:
#!/bin/sh
# symlink-ghost.sh - test for the stale symlink size bug seen on NeXTSTEP 3.3.
# Deleting a symbolic link appears to free its inode without clearing the
# inode's size. The next file created on that inode then starts out with
# the symlink target's length, filled with NUL bytes, even when it was
# opened with O_TRUNC.
# The test creates a symlink in a fresh directory, deletes it, then creates
# an empty file in another fresh directory. The filesystem normally hands
# that file the inode just freed by the symlink. On an affected system the
# "empty" file is 20 bytes of NULs.
# Usage: sh symlink-ghost.sh [directory]
# The directory defaults to the current one; it must be writable.
# Run it once per filesystem you want to check.
# Exit status: 0 = not affected, 1 = bug seen, 2 = test could not run,
# 3 = inconclusive (the freed inode was never reused).
dir=${1-.}
cd "$dir" || exit 2
target=0123456789ABCDEFGHIJ # 20 characters
runs=5
hostinfo 2>/dev/null | sed -n '1,2p'
echo "Testing in `pwd`"
bad=0
reused=0
i=1
while [ $i -le $runs ]; do
d1=ghost$$.$i.a
d2=ghost$$.$i.b
mkdir $d1 || exit 2
ln -s $target $d1/link || { rmdir $d1; exit 2; }
sino=`ls -id $d1/link | awk '{print $1}'`
rm -f $d1/link
rmdir $d1
mkdir $d2 || exit 2
: > $d2/empty
fino=`ls -id $d2/empty | awk '{print $1}'`
[ "$sino" = "$fino" ] && reused=`expr $reused + 1`
if [ -s $d2/empty ]; then
bad=`expr $bad + 1`
echo "run $i: BUG - new empty file is not empty" \
"(symlink inode $sino, file inode $fino)"
ls -l $d2/empty
od -c $d2/empty | sed -n '1p'
else
echo "run $i: ok (symlink inode $sino, file inode $fino)"
fi
rm -rf $d2
i=`expr $i + 1`
done
echo
if [ $bad -gt 0 ]; then
echo "AFFECTED: $bad of $runs empty files inherited the deleted symlink's size."
exit 1
elif [ $reused -eq 0 ]; then
echo "INCONCLUSIVE: the freed symlink inode was never reused; try another directory."
exit 3
else
echo "NOT AFFECTED: $reused of $runs files reused the symlink's inode and were empty."
exit 0
fi
