Apple Thermal Transfer Printer aka Iic Scribe repair and cartridge info
Elemenoh
432
418
Bay Area
I've had an Apple Thermal Transfer printer on the shelf waiting for repair for a while and decided to dive into it.
It powered up but then something started smoking. Uhoh! It looks like at least one electrolytic capacitor (C27) severely leaked and may have damaged a nearby ROM.
Before digging in too far I pulled out the thermal transfer cartridge to see if it'd be replaceable. It looks proprietary on the outside, but is pretty simple inside. It uses 8mm wide thermal transfer tape. The spindles rest in openings in the enclosure. Those spindles are about 26.5mm OD and 24mm ID. I wasn't able to find similar tape online. If anyone who reads this knows of a source, please post a reply.
I haven't found a service manual online, so will be slowly taking it apart to repair the logic board and attempt to get it working again. I'll update this thread with progress.
Reactions: Mac84
Elemenoh
432
418
Bay Area
Well, this isn't good. It looks like the cap managed to leak all over the ROM. I managed to get it out of the socket while only breaking two pins. I'm hoping it'll work well enough to dump. Fortunately replacements are cheap.
Reactions: eric
Elemenoh
432
418
Bay Area
There was a lot of crust on the ROM pins! I used a USB rotary tool to scrape away the crud down to the shiny metal. A couple more pins broke off in the process. I soldered some leads on and by some miracle was able to get it to dump. the ROM dump is attached here, but not sure yet if it can be trusted. I've ordered a replacement EPROM so it'll be some time before I know for sure. In the mean time I'll replace the ROM socket and electrolytic caps on the board.
  • AppleThermalTransfer-Scribe-Printer.bin
Mac84
311
447
New Jersey, USA
www.mac84.net
Wow, excellent work trying to get this back up and running! I can dump the ROM from mine to see if they match.
The one ribbon I have always snaps unfortunately. If I tape it together it snaps again…
@Elemenoh, can you take picture of the cartridge holder assembly for the Apple Scribe thermal printer? I am trying to see about compatible ribbon cartridges. Sometimes some things are still used today after 30-40 years, usually in an industrial setting.
For example, certain Canon ink cartridges work with the Apple StyleWriter printers.
I see the picture of the ribbon cartridge, but I am wondering about any specific markings in numbers or words on it?
Elemenoh
432
418
Bay Area
Thanks @retr01!
The 28-pin ROM needed 33 trace repairs. All but two needed 40 AWG wire to make space for the socket pins. It was fiddly work but kind of fun to do. I got the replacement ROM and ROM eraser. The eraser I ordered has a euro plug which is weird. It came via Amazon next day delivery. Why would they have those in the US? Anyway, I need to change out that plug, erase and program the chip before the printer is ready for testing again.
Elemenoh
432
418
Bay Area
I programmed a ROM, popped it in and put everything back together. It didn't blow up which is nice, but the head is just clicking and lights are flashing on and off. Anyone know what this means? I'm still suspicious that the ROM dump may be corrupt.
@Mac84 Would you be willing to dump one of yours?
XodiumLabs
74
141
South Bay Area, CA
xodium.net
So I ripped apart my pretty busted up Scribe to find a TEC chip on it. Markings are TEC 7293-9137 EC-9137 8427AAA JAPAN
This is the dump from that chip, taken in Xgpro with a TL866II+, though because the TEC chip wasn't in its database I set it to the Intel D27128. So your mileage may vary.
  • AppleScribeTEC.BIN
Reactions: Mac84 and Elemenoh
Elemenoh
432
418
Bay Area
Thanks so much @XodiumRetro !!
That dump is identical to the one I posted previously, so that rules that out as the culprit.
I guess the next step will be going back to check my work on the board. Ugh!
Reactions: Mac84
