Assembling a Lisa
Adam
38
53
This week I’m going to put together a Lisa that I’ve had apart for some time while testing hardware. It should be fun to clean up the parts and get it all together again. I’ll post here as I make progress.
Adam
38
53
Some of these parts are quite dirty. This Lisa was in a junk pile for a long time. But it seems like it should clean up alright.
Adam
38
53
However, some of the parts are really yellowed, like this front bottom panel. I think I’ll need to retrobright this eventually.
Adam
38
53
Lid attached. This one is easy - just two captive screws underneath in the back.
Adam
38
53
Oops. I realized that the sides have to go on first. These are a pain, because it’s hard to reach the screw holes. I had to use a
right-angle screwdriver for one of the screws.
Adam
38
53
Here’s the power supply. There’s no need to test it, because someone already did it for me! 😂
I’ve installed it into the Lisa. Unfortunately, one of the knobs is broken on this one. Anyone know a source for these pots?
Reactions: KingDingus
Adam
38
53
I’ve installed the boards (more on those later), and reattached the rather grubby looking back panel.
Adam
38
53
I’m going to try turning it on and see what happens. I had to take the lid off (again!) because the vertical hold needed adjusting. But the computer is starting up! (I had to trick the front panel switch to make it start without the bezel in place.)
I have to come back to this later. So stay tuned for more!
Adam
38
53
I had to stop working on this for now, because the power supply has stopped working. I’ve got replacement caps on order!
ScutBoy
352
Northfield, MN USA
Is this the 1.8 or 1.2 power supply? Will be interested to hear how your Bill of Materials matches up; I need to do this work on my Lisa
Purdy
19
20
Yes, please share your BOM for caps on a 1.8A Lisa PS. I've got one that's due for a recap.
Adam
38
53
I’m stuck on the power supply. The pins on the rectifier were shorted so I ordered a replacement. But when I removed it, the pins are no longer shorted. It appears that the transformer on the left has a short? I’m not sure what to do next. Am I screwed here?
