BFEXTU's ProdigySE Project
BFEXTU
190
161
Thanks - I reached out to them. It should help provide some more info. At least one of them has a Rev B RAM Card...which is good, because I was sure I remembered them using zip RAM...and they did.
BFEXTU
190
161
Attached are the ProdigySE RamDisk Release Notes from December 21, 1987. They have interesting info about hardware configurations.
Also attached are some quick facts about the Prodigy SE from the SuperMac Dealer Support Stack for use by then dealers and Tech Support.
  • ProdigySE RamDisk Release Notes.pdf
BFEXTU
190
161
Here are the basics for my board:
U3 ROM ID:
1002813-2001B (3.0B)
U13 Gate Array: 1002812-1B
U26 PAL: 1002809-1B
U27 PAL: 1002806-1A
Board Rev: C
RAM Card Rev: A
RAM Card Size: 4Mb (specifically labeled)
PMMU: Yes
S/N: 1974167
Status: Working (except that the RamDisk software crashes - hoping to figure it out -- maybe the board is populated with a wrong rev part). The RamDisk app crashing is a problem that was known in 1988.
MacSE: 4Mb RAM, Old ROM, IWM 344-0043A (800K)
n.b. Prodigy SE is not compatible with FDHD -- known since 1989 -- if used with SWIM, will treat drives as 800K.
My XGecu T48 arrived today, so I will hopefully be able to read the PROM and PALs, but the FPGA might be more challenging (need to know the device ID and/or may not be readable).
There was a Rev B version of the RAM expansion card that used OKI Zip RAM -- populated the 1Mb and 2Mb configurations...and maybe also higher density configurations.
BFEXTU
190
161
With the ROM programmer, I was able to read and verify several identical AM2764A PROMs (that used to run in an old SMS SCSI controller).
BFEXTU
190
161
I tried using the ProdigySE in a "reloaded" SE config with new ROMs, SWIM and 800K drive on an older 4Mb SE board, and it seems to power on OK, but hangs as soon as I put in a disk. This symptom was the same whether I used SWIM or IWM. Has anyone else seen this kind of issue in a non-accelerated SE? I will try the same test using my new rev SE board. I am trying to figure out if the RAMDisk hang I am seeing changes with different ROM or RAM configs.
I have already ruled out System version - no version fixes the hang. The RAMDisk should just work, but there could also be some other issue with my SE motherboard or ProdigySE board. The other possible issue is that the SE RAM modules prevent the ProdigySE from fully seating into the expansion slot...but it seems to work, except for the RAMDisk. But, there could be a pin contact issue. I might look for a male-female mezzanine connector to raise the slot a bit. However, on the side of the connector closest to the SE RAM, the Prodigy connector pins are longer to account for this issue.
BFEXTU
190
161
Here is a summary of my testing so far to track down the RAMDisk app hang:
System 4.1 / Finder 5.5System 6.0.5Notes
A. Old Mac SE, 4Mb, Old ROMs, IWM, 800KBootsBootsStock Config, Sees all RAM
B. Old Mac SE, 4Mb, New ROMs, IWM, 800KBootsBootsSees all RAM
C. Old Mac SE, 4Mb, New ROMs, SWIM, 800KBootsBootsSees all RAM
D. Old Mac SE, 1Mb, Old ROMs, IWM, 800KBootsBootsSees all RAM, different 1Mb
E. New Mac SE, 4Mb, Old ROMs, IWM, 1.44MbBootsBoots800K only, different 4Mb
F. New Mac SE, 4Mb, New ROMs, SWIM, 1.44MbBootsBootsStock Config, different 4Mb
ProdigySE Rev C, 3.0B, Config ABootsBootsRAMDisk App Hard Hang
ProdigySE Rev C, 3.0B, Config BNormal Power-On, Boot Freezes with floppy
BlueSCSI boots
Normal Power-On, Boot Freezes with floppy,
BlueSCSI boots
Flashing Disk Question OK
RAMDisk hangs with BlueSCSI
ProdigySE Rev C, 3.0B, Config CNormal Power-On, Boot Freezes with floppy
BlueSCSI boots
BlueSCSI boots
Flashing Disk Question OK,
ProdigySE Rev C, 3.0B, Config DBootsBootsRAMDisk App Hard Hang
ProdigySE Rev C, 3.0B, Config EBootsBootsRAMDisk App Hard Hang
ProdigySE Rev C, 3.0B, Config FNormal Power-On, Boot Freezes with floppy
BlueSCSI boots
BlueSCSI boots
I think I have ruled out: SE board type, RAM - tested 12 different DIMMs, ROM configs (and that newer ROMs don't work - Prodigy likely reading/patching, etc.). All results point back to the ProdigySE having some issue and that the preferred working config for Prodigy Rev C 3.0B is: Old MacSE, Old ROMs, IWM.
So, next, I am going to take a look at the Prodigy for any hardware issues and may just reflow it.
BFEXTU
190
161
I think it supported up to 32Mb, but in practical terms, I don't think anyone ever went that high because of cost. Also, the Rev A RAM modules were originally made by Scientific Micro Systems, but they declared bankruptcy in 1988. Subsequently, SuperMac underwent a management-led buy-out to separate from SMS. My module is a Rev A 4Mb module by SMS.
I tried reflowing the connector pins on ProdigySE. It looked like some might have had insufficient solder and I thought there might be an issue access the "Lower" (SE Motherboard) RAM. But...no luck - the RAMDisk still locks up. However, I have a friend who has a 4Mb board with working RAMDisk, so maybe we can compare the boards and find the problem.
edit: Also, the largest module I ever used was an 8mb module (1988). I never saw a 16 or 32mb module, but I have also never seen a ROUS.
BFEXTU
190
161
It looks like the ProdigySE board probably requires something to be in the PMMU socket -- either the Levco BMMU placeholder or an actual MC68851RC16A. When there is nothing in the socket, there's no power-on beep, no boot process, and my ProdigySE generates a checkerboard pattern.
This issue occurred because I tried pulling the PMMU to see if it was related to the RAMDisk lockup noted above. I know someone else with the same config board, albeit with Levco BMMU blank, and their RAMDisk is working. But, no luck.
However, discovering the checkboard pattern is an interesting detail and probably indicates that the blank has some included sense and/or is a shorted-die placeholder PCB. Also, it was helpful to use the PMMU in my Mac II in place of the HMMU to test out VM, and it worked. So, worth the effort.
If you have a ProdigySE and you see the pattern below, there may be an issue with your PMMU socket or whatever is plugged into it.
BFEXTU
190
161
I was able to locate a 2Mb Prodigy/SE board, so I should be able to do some more VM experiments and also compare my PMMUs to the one in this board (if VM) works to see if my new old stock PMMUs are any good.
