CodeWarrior 9 resources?
iantm
111
52
Great Lakes
github.com
I've always wanted to dig deeper into coding for the classic Mac. Never done it.. Spent my career on high-level front end Javascript/Python stuff, only scratching the surface of any assembly or lower level code.
I like the Macintosh C Toolbox Primer. I'm enjoying slowing down and learning. Is there something like it for CodeWarrior, or any of there resources that you'd recommend getting started? Assume I really know nothing specifically about the Mac.
I'm interested in targeting System 7.1 – 7.5.
joevt
285
119
CodeWarrior Pro 6 was the last version of CodeWarrior to support 68K targets.
CodeWarrior Pro 4 was the last to run on 68K hardware?
CodeWarrior 11 is also an important version.
Some other notes:
I don't think CodeWarrior has documentation on Mac programming. It has documentation on targeting Mac 68K and PPC and such.
CodeWarrior comes with Metrowerks PowerPlant which is a bunch of C++ classes for doing UI stuff for building Mac applications.
CodeWarrior comes with example source code.
SitesOnFire
While not using CodeWarrior, I've gotten to grips with coding on my Macintosh Classic using Think C
There are various books here.
I also heavily recommend jcs' website as a resource.
along with his project amend hub which has lots of source code to read over, and is a great version control system.
https://amendhub.com/
I've been using his MacTCP code as a reference while developing my own software.
While coding on real hardware is fun, using an emulator can be much quicker, and I can do it on the couch with my mbp.
https://snowemu.com/
If you're into talking to an AI for help, I've found Claude much more knowledgable than Chat GPT when asking questions about ANSI C or the Macintosh Toolbox.
I've come from TypeScript & Java, all I can say is prepare to move much slower than you're used to, and many crashes.
iantm
111
52
Great Lakes
github.com
Thanks all! I’ll see what I think of CW pro 4. I like Think C for its simplicity, but I miss the complete lack of syntax coloring. Even a little for keywords would help.
I have been using Claude to tutor me. It’s been really helpful in explaining everything as I go pretty much line by line.
I’d been using both my se/30 and Mac but I hadn’t heard of snow, I’ll try that out too!
SitesOnFire
If you're planning of coding directly on classic hardware, or an emulated classic macintosh, the output will be black and white so syntax colouring won't exist :) It's a massive mindset change to go from a modern IDE to a very small screen which may not even fit the entire method in the screen.
I also forgot to mention that Think C comes with Think C Reference Database, which is a searchable database for coding on a classic mac. Forum member @eric has also made it available online here http://129.158.56.21/thinkc/
iantm
111
52
Great Lakes
github.com
I prefer the small screen, actually, for its focus. Maybe at some point I'll cave and try and run CW on my G4, or Retro68. For now I really enjoy the limitations of the small screen. Since I have a color and/or grayscale display in my SE/30(s) I was hoping some IDE might support it.
The debugging loop in THINK C is a little tedious at times too, but having never used CodeWarrior I don't know if that's just how it is. If CW doesn't have syntax coloring at all, either, then that's just how we'll have to do it!
ftech
20
25
I use CodeWarrior Pro 4 on my 9500 and it has syntax coloring. I believe that even early versions of CW had syntax coloring. The UIs, menus and even keyboard shortcuts are pretty similar to THINK C so if you are familiar with THINK C, you should find your way with CW. I find the CW debugger nicer to use than on THINK C. You can set breakpoints on the source files themselves and (at least) later versions of CW like Pro 4 have a nice handling of backtrace when your app crashes.
Reactions: iantm
iantm
111
52
Great Lakes
github.com
Fab!! I will give it a go. That's a must have with an IDE for me, I go cross eyed looking at code in only black and white. And a better debugger will be a welcome addition. Thanks!!
A colour Se/30 sounds like an awesome rig.
I'm going to use that and/or a LC475 for 68k development. And likely some old skool gaming and kid pix.
Sideburn
290
128
California
I was a Mac software developer from 1992 to today and remember when CodeWarrior died and XCode took over. Sad times. I loved CodeWarrior it made programming more fun and that classic metal stamp sound when the compiler finished (turns out the gate closing sound in Prince of Persia is the EXACT same sound sample! I just stumbled on that one day playing the game and realized that was a very familiar sound).
