In the process of setting up a floppy-less CC, I ran into a
"Disk initialization failed because the disk is locked!"
dialog at startup, which was raised in an endless loop:
I got around it by adding a 4.7K Ohm resistor between the +5V and RD pins on the floppy connector.
I'll change it to something more permanent, but the CC boots normally now.
