I already ordered a Crucial 250 gig SSD and this. The Maxtor HD case is still good, so I want to continue to use it.It should. But first I have to ask, what is the interface on the external drive connecting it to the computer? If USB, then it may be easier/cheaper to just buy and external case already designed for a SATA drive.
Example on Amazon, USB 3 and backward compatible with 2.0 and 1.1
Hmmm.If that adapter doesn't fit in the maxtor case (hopefully it will), I would look at an external hdd case that has a broad I/o choice like USB1/2 & FW 400/800. Something like this mini g-drive would do the trick & is pretty cheap (not my auction/no relation). IIRC they fit a 2.5" formfactor/SSD, are all aluminum, and would give you a lot of flexibility between Macs with the I/o.
Too bad that dual 1.25 MDD doesn't have FW800. Good luck!
If you want FW800, you can readily source a fw800 pci card on eBay. I saw a couple for $20 & is how I got fw800 into my quicksilver. Max thruput is 800mbits. Crushes USB2 at 480 but I suppose you need to have a FW800 device for that to make much sense.
This reminds me of my ext 1tb backup for my 08 a1048 mb. The case died a horrible drop death fracture but the guts survived - just the pcb and the hdd sitting as a book end on one of my book shelves connected to the mb via a long usb cable. lol jank I guess but it works for me.
Typically if you have only 1 device in the chain, either position should work. When you have two devices on an IDE/PATA chain, one has to be master and the other slave. But I would try it on Master first.
If the internal OSX HD has an option for master/slave instead of Cable Select, then set one to master and the other to slave, and do not use the CS position on the OSX HD.
