Dead TechStep
Elemenoh
460
449
Bay Area
After years of searching, I've finally scored a TechStep. Unfortunately it shows no power with a good 9V battery. I haven't ordered a power supply yet, but suspect it'll produce the same result.
Nothing is scorched and so far all of the joints I've checked look okay. However, 9V is not making its way from the daughter board to the DC/DC converter (U3) on the main board. And there is no voltage across the GND and +(9?)V pins of the daughter board. Continuity is okay from the 9V battery input through the caps and inductors.
There is what looks like good resistance across C1m, C2m, C3m and C4m. I haven't checked those with an ESR meter yet but they're tants/polys and visually look okay. The inductors are short across their pins. There's so little to this circuit that I'm stumped as to what's wrong.
Any ideas for what to check?
Elemenoh
460
449
Bay Area
While double-checking the connections from the battery and barrel, I noticed the ribbon cable was a bit too wiggly. After pulling lightly I found the battery positive connection was broken. Hopefully reattaching that will fix the issue.
Elemenoh
460
449
Bay Area
The power jack is center negative. I expected something to be blown from someone connecting a more typical center positive adapter. I don’t think there’s any protection against that. hopefully all this needs is to have these wires reconnected.
@splorp Have you opened yours up yet?
Elemenoh
460
449
Bay Area
I replaced the ribbon cable with one that's a touch longer. The TechStep still does not display anything on screen and still doesn't show voltage at the voltage regulator. Back to trying to following the path from the battery more closely.
Elemenoh
460
449
Bay Area
It powers up with a power adapter but still not with the battery. It’s probably something simple on that DC-in board but haven’t been able to figure it out yet. Anyway, this is good enough for now :)
