Dual Boot Linux Mint 21.2 and macOS with OpenCore Legacy Patcher and OpenCore Bootpicker
PatiB
Update: No luck. Tried several things:
- Installing mint via "ubiquity -b" ergo without boot loader => no luck
- In Linux "sudo systemctl disable systemd-boot-check-no-act.service" => failed.. does not exist, since I got no boot loader
- In Linux "GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor nvram_modify_on_write=0"" was a suggestion, together with "sudo apt purge os-prober -y" and "sudo update-grub" => All yielded the same result.
- In macOS "sudo bless --mount /Volumes/EFI --setBoot --file /Volumes/EFI/EFI/OC/OpenCore.efi" gave me an error: "could not set boot device property: 0xe00002e2"
- Also tried in Linux "sudo apt remove efibootmgr -y", and blacklisting efi changes via "echo "blacklist efivarfs" | sudo tee /etc/modprobe.d/blacklist-nvram.conf" and "sudo update-initramfs -u"
Now Gemini suggest to place an additional boot loader IN FRONT of OCLP... I don't know... that doesn't seem right. :(
NightSwing
I had lost all hope on attempting to get a dual boot to work until I came across your comments. I have endeavorOS(arch based) installed and blacklist efivars worked for me to not have to reinstall opencore after every linux boot. I cant imagine what else you could do. Are you using the ext4 driver in opencore or another boot manager to boot linux.
Reactions: PatiB
PatiB
I just yesterday in the evening found the seemingly real reason. I will try to get it fixed today/tomorrow and post an update for if other tinkerers experience the same pain! :D
PatiB
I found the solution. Finally.
The main issue is: in EFI in the folder OC/Kexts/AppleUSBTopCase.kext/Contents/PlugIns/ the file "AppleUSBTcKeyboard.kext" was missing after booting Linux, but instead I got an additional "FSCK000..." folder.
Not 100% sure but it seems that Linux did some scan and maybe considered that file corrupted and removed it.
Solution is very simple:
- Boot Linux
- sudo nano /etc/fstab
- Change "/boot/efi vfat umask=0077 0 1" to "/boot/efi vfat ro,nosuid,nodev,noauto 0 0" which prevents Linux from farting around in there
Then for me to finally get it working after this, since the boot I used to adapt this had already broke it again:
- Plugin OCLP USB drive
- Hold alt, power Mac on
- In boot picker, select USB (orange icon)
- In second picker, select internal ssd/drive
- Boot macOS, wait 1-3 min for OCLP to detect that you booted from USB
- let OCLP reinstall itself into your internal drive
- Reboot (not 100% needed, maybe)
- You might only be able to boot macOS from bootpicker now, so carry on:
- back in macOS do "sudo diskutil mount disk0s1" to mount your EFI partition
- in finder go into EFI partition
- download "ext4_x64.efi" from here: https://github.com/acidanthera/OcBinaryData/tree/master/Drivers
- add that file to EFI partition folder: EFI/OC/Drivers
- edit EFI/OC/config.plist
- find entry "OpenLinuxBoot.efi"
- Duplicate that whole XML-section and replace "OpenLinuxBoot.efi" with "ext4_x64.efi" so that both are loaded
- NOW you should in reboot finally see both OS in bootpicker :)
NightSwing
- Boot Linux
Great that you got it to work. Hopefully more people will be able to dual boot since the time of OCLP is sadly coming to an end.
michaela
Hello, since this is probably the only place on the internet that resembles the issues I am currently dealing with, here I am:
I am trying to establish a dualboot of CachyOS (Arch based distro -- a bit of hunch of mine what could or could not be a culprit here, see 11.7.1 flag 0x00000400) using OpenLinuxBoot trough OCLP alongside MacOS Sonoma 15.5. I've used both OP's write up (Method A to be precise, since that seemed like a perfect match for my use case) and the Dortania docs as a reference and currently I am just stuck left my head scratching. I followed the process step by step, yet when I do reboot into the OCLP boot picker, there is no linux entry. I've checked the config.plist for any errors, checked the Drivers folder (had to add the btrfs driver and did add an entry into the config.plist accordingly), still no luck. Searching the internet (as stated above) didn't provide many results -- if any. I have a bit of a hunch that there is something fishy with APFS snapshots and bless command in the works, since getting the system running in the first place was an absolute mess on its own and honestly it is a miracle on its own that it runs. But before I'll dive into this another can of worms, I decided to try asking here, maybe some of you encountered a similar issue? Any input will be very, very much appreciated.
Thank you kindly ❤️
michaela
Thank you kindly ❤️
Option B fixed this somewhat for me🙏🏻.
DannyBoy
Hello, fellow Tinkerers! Although real life has intruded on my tinkering over the last few months, I’ve managed to squeeze in a small project or two. One of my background projects during this low key period has been testing OpenCore Legacy Patcher (OCLP) on a variety of unsupported MacBooks in my collection, specifically in multiboot arrangements with multiple installations of macOS and Linux. I thought I’d share a few tidbits I’ve acquired along the way through my tinkering and invite others to contribute as well.
If the idea of adding a driver to your EFI from an external source is not palatable, or you run into problems with your particular filesystem driver, there is another option you can try. This one worked for me as well. Use a fresh config.plist file, not one with the Option A changes. (You did make a backup copy, right?)
For Method B: Chainloading an EFI Bootloader, Method 1: Using BlessOverride
This method requires that you know something about your Linux distribution’s bootloader, at least enough to recognize what bootloader your distribution uses and where it lives. There are some hints below, but by no means is it a comprehensive list.
  1. Edit config.plist in your favorite editor (I used TextEdit)
  2. Find the BlessOverride entry under Misc - in my case it was set to \EFI\Microsoft\Boot\bootmgfw.efi, which I believe is the default configuration to dual boot Windows; I did not see this driver contained in the Drivers directory from installation of OCLP, so I figured I could alter this entry with no ill effects
  3. Look for your Linux distribution’s bootloader under EFI, and change the BlessOverride entry to match your bootloader; some common ones are
    1. \EFI\arch\grubx64.efi
    2. \EFI\ubuntu\grubx64.efi (this is what Linux Mint 21.2 uses)
    3. \EFI\systemd\systemd\systemd-bootx64.efi
  4. Exit and reboot - an EFI entry representing your Linux install should appear in the OpenCore bootpicker along with the various flavors of macOS installed previously
There are other methods listed in the Dual Booting with Linux source which I didn’t try. In the end, I chose Method A as my preferred method since it shows the actual Linux kernel by name instead of a generic EFI entry shown in Method B1.
Have any of you experimented with multiboot arrangements with different Linux distros or other OSes? What bootpickers and methods did you try, and what worked well or not well for you? I would love to see your experiences below!
Thanks so much for this super helpful, detailed post. You solved a problem I had beating my head against for hours. My system: MacBook Pro early 2015, Fedora dual boot, so very close to yours. Your solutions worked exactly as described, and everything works.
Best,
Dan
