@max1zzz first mentioned his work on a Radius Rocket prototype here. I was informed about his MLA thread on the subject today. Specifically, it seems he now has a working board:
I have an original Radius Rocket 33 with a full FPU 040, installed in my IIci. Here are some pics:
Max, is there are reason you chose to go with the 25MHz GALs instead of 33? Is it because you had no access to the 33MHz edition GALs?
Honestly, it would be great if the GALs could be revised to work at 40MHz, especially because some 040's can clock that high. Although even at lower clock speeds, Radius Rocket's pull a huge amount of current from the power supply...
As a result, it gets pretty hot. You can see the temps on mine, using a UTi260B thermal camera...
