Galena – a free board diagnosis tool for techs (Mac and Linux), *preview*
idabbleinit
Missouri
maketokeep.com
Howdy!
I have been building something for the bench and it is at a point where I want it in other techs' hands. It is called Galena and it is a tool for techs, made by a tech, and it is FREE. No account, no subscription, no catch – download it and use it.
What it is (a diagnosis tool for sick logic boards)
Galena is meant to take the guessing out of a dead board. Is it power, the clock, the ROM, RAM, a chip, or a trace that a leaky cap ate? Galena walks you through it one question at a time, tells you what to measure and where, and narrows it down until it points at the part. Every fact it shows says where it came from and how far it is trusted (Proven, Official, Likely, or Reported) so as to keep the folklore separate from what has actually been checked on a real board.
It is built around the way we already work – a meter, a logic probe, a scope, a phone camera and your ears. You do not need any special hardware to use it.
What it does right now;
- Repair – the step by step walk. Where a step wants a test, "I'll measure it myself" tells you where to probe and records what you saw, with the tool, the value and pass or fail.
- Board – every part of the board grouped by kind, what each one does, the tests that touch it, and what can stand in for it (made today, old stock, donor only, remade, reprogrammable) with sources. Drop in a photo of the board, box the parts once, and you have a map of your own board.
- Capture and Board Log – it checks your pictures are sharp enough to read before keeping them, reads the labels and chip markings (you confirm every one, nothing is taken as fact on its own), and keeps a log that follows the board: received, inspected, fault found, repair, tested, passed on. The log is chained so a changed or missing entry shows, and it prints a small QR tag and a card to send with the board. No names, ever.
- Schematic – follow a signal pin to pin. The SE/30 comes with a full netlist from an open redraw (186 parts, 526 signals). For anything else, build your own one connection at a time and export it to KiCad or a spreadsheet.
- Listen – beep codes by ear. Hold the mic to the speaker, or type what you heard, and it tells you what each BIOS maker says it means, with the source.
- Lights – POST codes and debug LEDs read from a photo of the display.
- Diode – diode-mode readings against a known-good board, pin by pin: matches, differs, or short to ground.
- Share – shows exactly what would go into a shared library, with anything personal stripped first. Nothing is sent from this version; it saves to a folder so you can look.
- Add a Board – it ships with the SE/30, IIci, Quadra 605 / LC 475 and the 7200, but it is not locked to those. Add whatever is on your bench – classic or modern, Mac, PC, Amiga, whatever.
What it plans to do;
The Galena hub is still being built and that is where this goes next. It talks to the board through the places the board already has, no soldering – a diagnostic ROM in the ROM SIMM socket for the SE/30 and the Mac II family that tests the board with no working RAM and reports back, Apple's own Test Manager through the modem port, a probe for signature analysis compared against a shared library of known-good boards, a card that watches the PDS slot, and a clip for a PC board's BIOS chip. When it ships the test steps in the walk answer themselves.
Also on the list; the shared library (so what one tech finds helps the next), more boards, Award BIOS codes, Memtest86+ logs, and logic analyser captures. The software stays free – the only things that will ever cost anything are the physical tools, and you never need them to use Galena. The details for makers who want to build their own cards for obscure systems get published with the full release, because those cards can only come from the outside, I do not have every machine and never will.
- This is a preview. It is not signed by Apple yet, so the first time you open it macOS will balk – go to System Settings › Privacy & Security and hit Open Anyway (on Sonoma, Control-click › Open works too). One time only.
- Mac: macOS 14 or later, Apple silicon or Intel. Linux: x86_64 with GTK 3 – unpack it and run ./galena, same screens, same words.
- There is a full guide (PDF) on the page that goes through every screen.
Download and guide: https://maketokeep.com/galena/
I plan a Windows version that will come with the others at release.
The point of all this is to keep these machines alive, and the techs who keep them alive need robust tools that do not cost a fortune. I would really like to hear from people who put it on a real bench – what is missing, what is wrong, what boards you want in it, anything. thoughts?
– Scott
