[HELP NEEDED] Changing the long mini DB8 cable to connect from Mac to IW II printer
So, I am not sure if I want the new AirTalk thingy by Cheesestraws over at 68kmla because of the reported slow throughput and slow printing than normal. A LocalTalk card for the Imagewriter II printer is insanely priced off eBay. o_O And I don't want to go to the LocalTalk route, anyway. I'd rather my IW II printer have the memory buffer card I picked up for just $5 off eBay. :sneaky:
I will get a 25 feet long mini DB8 serial cable. I realize that one end needs to be adjusted so that the TX and RX are switched appropriately to connect a Mac to the IW II printer. I noticed that @joethezombie mentioned chopping off one end and attaching a new mini DB8 connector with changes to the pin-out:
I have trouble understanding how exactly it is done. :cautious: Can someone please show me pictures or videos of how it is done? Thank you. :)
Crutch
292
226
Chicago
Are people actually claiming AirTalk results in slow printing? Cheesestraws indeed stated that AirTalk is slower than wired LocalTalk, but if you’re printing to an ImageWriter II the print speed ends up being like 1000x slower than the speed for network traffic so I would be surprised if print speed was impacted in any human-noticeable way at all.
Reactions: skate323k137
Ah. No. I see that my words didn't come out right. Sorry. Thank you for pointing that out.
Correct.
Reactions: Crutch
Let me clarify.
I want to do this the old-fashioned way via a serial cable, but I need 25 feet because six feet will not work for my setup. That is why I want to understand better the process of rewiring one end to the correct pinout.
I can get a 25' mini DB8 serial cable cheaply, but it needs modification at one end for proper connection from the Mac to the IW II printer.
  • What do I need to get to replace the connector at one end?
  • After I strip off the end and spread out the wires, what method is to attach to the new connection according to the correct pinout?
Pictures or videos will help me better understand what is needed. Was there a book that explained that already? Did Larry Pina explain that? Another author? Someone else? Who?
Volvo242GT
296
161
Currently Duvall, WA
Just grab a couple of these and connect your Apple MD-8 cable to them.
26 feet.
There's also this 20 foot male-male MD-8 cable, made by Belkin...
26 feet.
Is this going to mess up communication between the Mac and IW II? Is the pinout the same as the printer serial MD-8 cable?
Ah, it might be too short. Thank you for finding this. :)
Volvo242GT
296
161
Apple uses only one Mini-8 DIN cable for both printer and modem functions, so no rewiring necessary. As long as you aren't planning to use the setup with a Super Serial card, you won't need anything but the Belkin cable and one of the extension cables from the other auction.
Thank you, @Volvo242GT.
There are two main types of serial cables, a null modem and a straight through. Hence, the concern about the correct pin-outs. IIRC, the IW, IW II, and other Apple printers using serial MD-8 cables need the null modem type to flip the TX and RX pins rather than straight through to support the required handshaking. That is why I was concerned and wanted to be technically specific.
Now I understand why I was confused.
I got an MD-8 serial A/B switch box months ago, so two Apple computers could share the IW II. I had to get a straight-through cable from the box to the IW II printer and connect the regular null modem cables from the computers to the box.
I still have not set up the box because now I have the Mac SE, SE/30, IIci, and Apple IIGS. So, I changed my plans. I had to place the printer in another area and needed a longer cable. I plan to hook up my SE/30 to the printer, and the SE/30 will become the print server on the LAN.
The null modem MD-8 serial cable is the "regular" MD-8 serial cable required by Apple for printers, modems, etc., while the straight-through cable is for direct connections like the computer to computer serial connection or between the printer and switch box.
Now, @Volvo242GT, you showed a page that listed different part numbers for the MD-8 serial cable depending on which Apple computer. Is that because the cables are different with the pin-out for the Apple II (using a Super-Serial card), Apple IIc, Apple IIGS, and the Macintosh computers?
Volvo242GT
296
161
With respect to the different cables, the ones used with the Super Serial card are different, since one is meant for the Apple Personal Modem (or for hooking up a non-Apple modem to a Mac or IIgs), and the other is meant for printers, like the IWII and the StyleWriters, etc. The DB9 to MD8 cable is like the regular MD8 to MD8 cable, in that it can be used with either peripheral, or can be used to connect a Mac Plus (or later) or IIgs to a 1st generation IW.
